Boat House
carpet on aluminum
<blockquote data-quote="fender66" data-source="post: 184718" data-attributes="member: 2990"><p>I think it all depends on quality of carpet, kind of glue used, and surface it's glued to.</p><p></p><p>I had cheap astro turf on my aluminum deck. That came up easily, but the glue was another story. I used a grinder with a brush for hours and ended up having to get Aircraft stripper to thin the remaining glue. I went through almost a gallon of that before I had all the glue cleaned off. What a mess that was. Took several days of work....and this was just my front deck on a 1648.</p><p></p><p>As for gluing down new carpet....just be careful in your cutting....and use a good outdoor carpet glue. You shouldn't have a problem.</p></blockquote><p></p>
[QUOTE="fender66, post: 184718, member: 2990"] I think it all depends on quality of carpet, kind of glue used, and surface it's glued to. I had cheap astro turf on my aluminum deck. That came up easily, but the glue was another story. I used a grinder with a brush for hours and ended up having to get Aircraft stripper to thin the remaining glue. I went through almost a gallon of that before I had all the glue cleaned off. What a mess that was. Took several days of work....and this was just my front deck on a 1648. As for gluing down new carpet....just be careful in your cutting....and use a good outdoor carpet glue. You shouldn't have a problem. [/QUOTE]
Boat House
carpet on aluminum
