- Joined
- May 15, 2010
- Messages
- 3,680
- Reaction score
- 343
- Location
- Central Florida
- LOCATION
- Lake County, Central Florida
Okay......I tried to steer you into a twin cylinder for vibration reasons. Here is a quote. One of many you can find on the internet concerning single cylinder outvboard engine vibration issues.
"No one has mentioned it yet, but there is a problem switching from a two cylinder 2-stroke outboard, to a single cylinder 4-stroke outboard of similar horsepower or weight. My 56 pound 6hp Nissan single cylinder 4-stroke replaces a 48 pound 8hp Johnson two cylinder 2-stroke. The original swing-up engine mount cannot take the increase in vibration of the single cylinder 4-stroke outboard. That vibration hammers away at the mount. Yesterday, my engine mount broke another stainless steel bolt. The first time that happened, I replaced the broken bolt with a galvanized high quality steel bolt of the same size. After disassembling the mount today, I noticed that even that high quality bolt had wear after only approximately 5 hours running time. My plan is to modify the swing-up mount by installing the largest bolts that can fit the pivot points in the mount (with modification of the cushion material). Of course, that means that the brackets will have to be drilled-out to larger size holes. Still cheaper than buying a new $330 mount built for the 4-stroke engines, and going through the hassle of bolting it to the transom. Look at the West Marine pictures of the 4-stroke mount. Looks like the bigger bolts are what is required. Just giving everybody a heads-up on this problem."
Followed up by........
"Hello Doug: You might as well get used to it I bought a new 4stroke 5hp Tahotsu (same motor) and it is a pretty bad motor, in my opinion. It shakes, runs poorly on Idle, and vibrates so badly that we feel it in our inflatable RIB. I took mine back to the dealer three times before they finaly replaced it now not only does it do all the other things I mentioned it now also wines (kinda like the owner). I dislike mine so much I won't use it. Good luck "MIC"
Then......"they" all think it is the propeller.
Do what you want but you may not be happy with a single cylinder
You may do well to read a few Profiles in here to see if a few of us know what we are talking about!
