monsterkat11
- Joined
- Aug 10, 2008
- Messages
- 27
- Reaction score
- 0
started work on my 16 foot flat bottom. started out with the back transom, unfortunetly the way it was made, the back braces were welded to the transom, there was literally no way to get one solid peice of board, all the way across behind it, ended up using two pieces of 2X6 and two 2x4's with a plywood brace on the outside, as well as the back. The Next Thing i did was started the framework for the front deck. there's still a few things we need to do to support the front more, but we decided to knock out cutting out the deck template last night too
The Transom
Back Support
The Start Of Framing
The Boat
In The Middle Of Framework
Template
Template With notches
The Transom
Back Support
The Boat
Template
