Flooring
Talk about anything that floats your boat (no pun intended). This is general talk about anything not related to boating/fishing.
bigmofodad
Flooring
Post by bigmofodad »
I’m going to redo the inside of my boat. I’m going to use 2 x4s as. Stringers lay my plywood on. If I totally paint the tops, bottoms and ends will that keep them from rotting out or would a normal waterproof stuff
DaleH
5
Flooring
Post by DaleH »
Well, truth is, if you could keep water off & away from it & keep it dry, in a totally dry bilge ... then one wouldn’t need to waterproof it at all. Personally I’m a totally encapsulated in epoxy man myself ...
#1) 1st tin rebuild, 18' Lund https://forum.tinboats.net/viewtopic.php?f=21&t=36583
#2) 25' Parker refurb from EMPTY hull https://www.classicparker.com/phpBB3/vie ... p?f=15&t=6
#3) 16' V-tin rebuild https://forum.tinboats.net/viewtopic.php?f=21&t=36465
#4 Procraft SV14
#5) 16' Starcraft entirely NEW Transom Skins https://forum.tinboats.net/viewtopic.php?f=3&t=37548
bigmofodad
Flooring
Thanks for the advice
jethro
6
Flooring
Post by jethro »
Any wood that goes in my boats gets old timers formula and then 5 coats of spar varnish. Should last 30 years even in a damp environment with that treatment.
I fish, therefore, I am.
1993 Starcraft SF 14 DLX side console with 25 hp Mercury 2 stroke
2003 Sylvan 2100 Profish walkthrough with 150 Mercury Saltwater and 6hp Mecury 4 stroke kicker
Flooring
Post by Captain Ahab »
I replaced my wood floors with azek board over alum. bracing. No rot never
Painted it with non slip marine deck paint.
jethro
6
Flooring
Post by jethro »
Captain Ahab wrote:
21 Jul 2019, 08:56
Is the Azek a lot heavier than say, 5/8" or even 3/4" CDX? Or would you say it's close?
LDUBS
3
Flooring
Post by LDUBS »
I had the same question. It is a PVC material. Specs I saw say a 5/8 4x8 sheet weighs 55 lbs.
Have Rod - Will Fish
jethro
6
Flooring
Post by jethro »
LDUBS wrote:
22 Jul 2019, 10:46
Well that's pretty close. Interesting.
