The Flats Tracker Project (1983 Bass Tracker) FINISHED
rook
Post by rook »
Been keeping my eye on CL for a while trying to find something that sparked my interest and was in the right price range. In other words something that was cheap, but also something that was a good base to start a new project on. Well last weekend I ran across a 1983 Bass Tracker 16ft with a 1983 Mercury 50hp 4-cyl. The price was right and I just couldnt pass it up. Needed alot of work but was actually water ready. Good tight motor with good compression and the hull was in really good shape. Boat was all original down to the trolling motor and everthing was in working condition. Shes not much to look at but just give me a little while.
I started stripping it down pretty much the moment I arrived home. The floor was rotten and the carpet was in rough shape and I wasnt real happy with where the console was located. At first this started out as just a replace what was bad and paint but the further I dug the more the picture I had in my head changed. Actually its still changing. But as for now Im finished up ripping everything out and after a little mock up of the new "addition" I bought this weekend we are gonna pull the motor and get ready for paint. After paint is when the fun begins. I will keep this thread updated with pics as the progress goes. Im thinking of going to "flats boat" route but will see. Its definately going to get a center console instead of the side console and im shortening the back deck about 14".
Getting the back deck tore apart was a job in itself. I never imagimed that it was all alum with no wood.
Inside completely stripped (well as far as I need it to go atleast)
1983 Bass Tracker 16' *Flats Tracker* (Under Construction)
https://www.tinboats.net/forum/viewtopi ... 21&t=13410
1979 Fisher Marine 14' Jon (Finished)
https://www.tinboats.net/forum/viewtopi ... 21&t=13392
Froggy
This years project (1983 Bass Tracker)
Post by Froggy »
Looking forward to the mod, good luck
dixie_boysles
Post by dixie_boysles »
looks just like my fiance's Dad's boat! He redid his entire inside. Even mad a rod locker for it!
270Handiman
Post by 270Handiman »
That's a great layout! It sets up perfect for a mud motor.
270Handiman
If you can't get what you want, work with what you have!
My current project: https://www.tinboats.net/forum/viewtopic.php?t=12125
rook
Post by rook »
Got the Poling Platform fitted last night. Had to make sure of the mounting location before I pulled the motor and started the paint process. Going today to pick up a free (I love that word) 14 gallon alum built in fuel tank from a friend. Got to figure out how to make it work and then off with the motor and its time for playtime with the orbital sander and grinder!! I can see a redfish stalking and quacker killin machine in the makin.
sturdi87
Post by sturdi87 »
rook wrote: but the further I dug the more the picture I had in my head changed. Actually its still changing.
hah story of my build as well! Good luck! But looks like you found a great "base" to start from!
My 14' V project with 40hp Mariner and 7.5 Johnson: https://www.tinboats.net/forum/viewtopi ... 21&t=12448
cavman138
Post by cavman138 »
Nice boat to start with, can't wait to see what the finished product looks like.
My work in progress:
My PolarKraft 1648 Mod!
WaHooWa
The definition of insanity is doing the same thing over and over and expecting different results.
Outdoorsman
Post by Outdoorsman »
Nice boat....looking closely at your first picture...I have never seen a TV Satilite Dish mounted on a Bass Tracker before.... :lol:
Seriously...I am on my way (tonight after work) to look at a 1980 Bass Tracker II..looking at your pics gives me an idea of how she is made.....looks like I might be joining the club....
I will start a new tread with with pic's if all goes well.
1990 24 Ft. Preimer Pontoon Boat W / 50 HP. Mariner = Relaxing on the Water...
1980 17 Ft. Bass Tracker II Mod-V Hull Jon Boat with 45 HP Merc = Lakes and River Boat...
10 Ft "Bass Tender" (Plastic) Tri-Hull W Plastic Oars = Local Area Ponds..
jdrautoworks
Post by jdrautoworks »
Outdoorsman wrote:Nice boat....looking closely at your first picture...I have never seen a TV Satilite Dish mounted on a Bass Tracker before.... :lol:
I would look very closely to the bow for cracks, and the first rib on the bottom of the boat from the left (drivers side). I a currently restoring a 80 BTIII and two problems I've found out is the bow is a week point for cracking. And on the BTIII they ran the trolling motor wiring under the floor and the insulation breaks down from water and arcs on the boat causing holes in the hull not to mention electrolysis... Just my two cents.....
rook
Post by rook »
Ill take a look at that as well on this boat. All the wiring on this rig was through the walls. But I will tak a closer look at the bow.
remmi597
Post by remmi597 »
I just got a 1983 with 50 merc the back end has no deck, watching to see how you do yours. Looks like an intense project.
rook
This years project (1983 Bass Tracker) *Update 5/17*
Post by rook »
A little progress, between showers this weekend was able to get the new trailer bunks and guides on as well as finish prepping the hull for paint. After doing a little research I ended up on the phone with a local company (Research Products) about what I need to do to get ready for paint. The duck boat that I did last year was factory painted unlike this one which is bare alum. Anyway after calling around I end up with a product called "Luma Brite". Man this stuff does its job and does it well. After getting all the stickers and sticky of the hull I applied the first "coat" of this stuff. Let sit 5 minutes and wash off. Then one more time and just look at the pics. It cleans, degreases and etches all in one step. Good stuff!!
Old
New
Luma Brite
Before
After first wash
After second wash
That Robbie Guy
This years project (1983 Bass Tracker) *update 5/17*
Post by That Robbie Guy »
Note to self ... Luma Brite.
Thank you sir.
rook
Post by rook »
Its good stuff man. All the info is on the bottle so look at the pic to get phone number. Its made here locally but Im sure they can ship. Silver Ships, which is a big ship builder down here has done away with sandblast by using this stuff. I mixed mine 8:1 and it started foaming as soon as it hit the hull.
rook
Post by rook »
Oh yeah I forgot an important update. Sold the '83 Merc 50 and picked up a '90 Mariner 50 w/tilt and trim.
