Benjineer's Lund S-16 Mod
benjineer
Post by benjineer »
Here are the before pictures. I bought this in July in WI and hauled it back to MS. From what I can tell, it is a '77 model with '85-'87 model motors. I plan to remove most of the middle bench and adding a floor, front casting deck, and bow-mount trolling motor. Planning to make this a bass and inshore saltwater machine. I'm not going to get super fancy with it. It will be carpet-free, but it might get some new paint. I'll try to post here and another site I've been getting ideas from. Thanks for looking. Advice and ideas are welcome. That's what I'm here for. This is the 3rd boat I've worked on. The others are on my personal website at benjineer.com.
'77 Lund S-16, '94 Johnson 48SPL
'03 Striper 2101 DC, '03 Optimax 150
benjineer
Post by benjineer »
Here are more pictures of the progress. Trying to get up-to-date since I was already posting on another site. Someone had asked how you operate two tillers at once. Here is a pic of the clamps that are on each for "cruise control". The steering is linked with a tie bar.
Stripping it down and removing most of the middle bench. I decided to leave some for support, etc. for now.
That gave me a 28" walk-through space. Then I went back and cut some more out which left about 29-1/2". The little benches will be about 15" wide. I had the pieces I cut out folded into some end caps for the small benches and some L-brackets for mounting other things. Here are some pics of the floor going in and out. I'm still not satisfied with it, so it is coming out to get more support underneath. I'm not attaching the wood frame to the Al floor braces, but it will not be removeable when I'm done. The floor is 1/2" treated with 2x4 stringers. It's heavy right now, but the wood is still wet. As purchased, it topped out at 19mph with two guys and a light load. 17mph when we added two more. I've got a feeling I'll be wishing for more power when I'm done, but what I have will have to do for now though.
Here's one of the fuel tank where it goes. This is after I added a sending unit and reconfigured for proper venting, of course you can't see that part for the bottle. More on the fuel tank later.
nathanielrthomas
Post by nathanielrthomas »
Twin 9.9 engines??!! :idea: :idea: How fast do those babies push that tin? You got me thinking brother....
benjineer
Post by benjineer »
nathanielrthomas wrote:Twin 9.9 engines??!! :idea: :idea: How fast do those babies push that tin? You got me thinking brother....
I ran it as-purchased on a lake in WI that my inlaws live on. With about 6 gal gas and 350lbs of people it ran 19mph GPS. 17mph with about 650lbs of people. I only ran it once with just me, but didn't check the speed. It planed higher and felt faster, so I'm guessing around 21. I also pulled my wife on a tube and was pleasantly suprised. I think I could've tossed her off if I'd been trying. The boat is rated for a 40HP. I do have an '05 Johnson 9.9 long shaft I could put between them if there is room. Wouldn't that be crazy? Probably wouldn't be safe if I couldn't link the throttle cables together somehow. One engine wide open doesn't do much, so if you need to slow down in a hurry, killing one will do it.
free jonboat
Post by free jonboat »
how would u steer all 3 engines :LOL2:
aint no stoppin once the deer start droppin
benjineer
Post by benjineer »
I'd need a tie bar for trips or weld something on the existing tie bar. I might have to start over because I'm not sure there's room for a third with the spacing as it is. I seriously doubt I'll go there. If 20hp is not enough, I'll probably sell them and buy a single 35 or 40.....or 2 20s...hmmm.
Troutman3000
Post by Troutman3000 »
First Off, Nice TIN!
I would sell those tens in a heart beat and get something bigger and with one set of controls. Using that setup all the time would be tiresome and not very fun after a while. Seems like a lot to pay attention to while trying to drive a boat.
perchin
Post by perchin »
I'll be keeping an eye on this one...... Not to be a downer, but if that plywood is Pressure Treated, get it out of there soon!!! PT ply will react with the aluminum and cause pitting and corrosion fast.
benjineer
Post by benjineer »
Troutman3000 wrote:First Off, Nice TIN!
Thanks! It's not as difficult to operate as I thought it would be, although I agree that a single would be simpler. It would be annoying if doing a lot of starting and stopping like pulling a tube or something. Here's the drill when running them both. Crank them both, go to full throttle with both, then don't touch the far one until you are ready to stop. You can alter speed dramatically by backing off on the one engine, since it will not stay on plane with just one. If I'm staying in one general area and just moving around a little, I just pick one engine up and use the other one.
benjineer
Post by benjineer »
perchin wrote:I'll be keeping an eye on this one...... Not to be a downer, but if that plywood is Pressure Treated, get it out of there soon!!! PT ply will react with the aluminum and cause pitting and corrosion fast.
Thanks for the advice. I've been reading some about that. I'm planning to pull everything out and put some fresh paint inside the boat and on the wood as well. I will do my best to keep it out of contact with bare aluminum. I may even put some rubber coat or bedliner in areas where there could be rubbing. Is marine plywood ok? That is what was on the bench seats, and I plan to re-use some of it.
benjineer
Post by benjineer »
I really like that yours is all aluminum. That is nice. Mine will probably get stripped and redone in the not-too-distant future. I'm just too undecided on the layout and to anxious to use it to go that far right now. The final build will probably have side storage like yours, and removal of the rest of the middle bench. I guess I could have gone with non-treated wood if it's that temporary.
cavman138
Post by cavman138 »
wow we always joke around about having twin 9.9's. I didn't know there was a boat that actually had them. That's pretty funny.
My work in progress:
My PolarKraft 1648 Mod!
WaHooWa
The definition of insanity is doing the same thing over and over and expecting different results.
benjineer
Post by benjineer »
cavman138 wrote:wow we always joke around about having twin 9.9's. I didn't know there was a boat that actually had them. That's pretty funny.
Whoever did this planned it that way. The engine serial numbers are really close. They must have bought them new as a pair. The transom has some rot as you can probably guess from the aluminum plates on front and back. It's plenty sturdy for the little guys, but if I start looking at a single 30-40, it will require some more work. Looks like I've got to take a break for now. Promised I'd make some progress on our bathroom this weekend, and work is sending me to CA all next week.
You need to paint that boat and motors ferrari red! :beer:
Please use our Amazon Affiliate link. It costs you nothing and sends a few cents to the site.
Amazon Link!
benjineer
Post by benjineer »
Ok, need some help here. What size aluminum framing would you recommend for the casting deck? I was thinking 1-1/2 x 1/8" angle because it seemed to be the most popular on here. Also, if I wanted to deck it with aluminum, what thickness would you use? I attached my front deck that will hold the trolling motor this weekend. It is made from some al treadplate. I know I'm doing it out of order, but I had that ready and wanted to see what it looked like. I can take it back off to work on the casting deck. I also mounted switches and gauges, but did not hook them up. I will try to get some pics up.
