Nussy's PonTIN boats
Nussy
Post by Nussy »
Well it's build #3. Here's my blank slate to start with 2-24' pontoons 18" in diameter. Found on Craigslist..a little beat up but it's really hard to find used pontoons....or even a trashed old pontoon boat.
I plan to cut them in 1/2 and build two similar boats out of it. I figured I can learn on the first one and make some tweaks for the 2nd build and sell the first one. Here's the layout of how I plan cut them up.
Then I'll basically take the 12 foot pontoons and build this. Current plan is 6 foot wide with a deck of 9' long. bow and stern trolling motor setup. I'm thinking 100" aluminum....but I do have some carpet to burn from my last build so we'll see how the budget goes.
Open to suggestions. Stay tuned.
Howard
Post by Howard »
Man, you have to much time on your hands, LOL. Good luck and look foward to see your progress =D>
Nussy
Post by Nussy »
Howard wrote:Man, you have to much time on your hands, LOL. Good luck and look foward to see your progress =D>
It's still winter here in WI. 14" of ice on the lake. 3" of snow today. At this rate I'll have both done before ice out :LOL2:
minicuda
Post by minicuda »
very cool i'll be watching this one!
PHIL 4:13
My build pics album Custom diamond plate 2003 g3 side console
https://s154.photobucket.com/albums/s27 ... 0G3%20mod/
Post by Waterwings »
Looking forward to the build! 8)
hsiftac
Post by hsiftac »
cant wait to see how this goes
Outdoorsman
Post by Outdoorsman »
I am in Wisconsin... I got first dibs on your first build when you decide to sell it...
Awesome idea...
Outdoorsman.
1990 24 Ft. Preimer Pontoon Boat W / 50 HP. Mariner = Relaxing on the Water...
1980 17 Ft. Bass Tracker II Mod-V Hull Jon Boat with 45 HP Merc = Lakes and River Boat...
10 Ft "Bass Tender" (Plastic) Tri-Hull W Plastic Oars = Local Area Ponds..
jasper60103
Post by jasper60103 »
Yea, this winter has been very painful in Mn. The garage is just getting warm enough to start winter projects, LOL.
Look forward to your progress.
2018 Tracker Grizzly 1648
Nussy
Post by Nussy »
Well I got the first set of pontoons back from my fab guy. Obviously, these are the front half of the 24 footers. I think they turned out pretty good, he said they were a nightmare....hoping the bill didn't double.....I'm supposed to get the other two this week
About all I got done this weekend was I figured out how I'm going to lay everything out. New plan calls for the deck to be 6' x 8'. Found some aluminum decking that I really like only problem is it's 7 hours away....I really want to do it right since this boat will be sitting outside all the time. Guess I'll have to bite the bullet on the shipping.
I also polished the pontoons up a bit.
Before
After
basstender10.6
Post by basstender10.6 »
good start. this is going to be a cool mod
2000 Procraft 190 SuperPro
2000 Mercury 175 EFI
Nussy
Post by Nussy »
Yesterday I cleaned up the tubes with a product call ZING. It's pretty nasty stuff(has hydrochloric acid), but it does a really nice job to make aluminum look almost new. Today I spent a couple hours and got the frame installed on boat #1 today. The guy I had cut the pontoons, still doesn't have the 2nd set welded up, so I'm stuck for now. I decided to go with 2" x 1" x 1/8" C Channel. I wanted do do Bassboy's hat design, but this was a little easier and cheaper since I could buy it stock and didn't have to find some one to cut it and bend it. I also ordered the decking this week. I decided to use a product called Last Deck https://www.lastdeck.com. It's powdercoated aluminum decking. It was a little pricey but I think it will be worth it since this boat will sit outside all the time. It should be here in a couple weeks. Here's a pic of where it stands today.
hsiftac
Post by hsiftac »
ive been waitin for some pictures on this one, thank you! this looks awesome and cant wait to see more progress
bailey86
Post by bailey86 »
one my realitives have a pontoon turned into a dock and cut a hole in the middle of it and droped a stainless steel tube from a washing machine in it and works great for a livewell would there be room for something like that
Bugpac
Post by Bugpac »
Looking good, I think if it was me, I would weld a end across the c channel on each side, I use to build crest pontoon boats 20 yrs ago, seems like we did this to strengthen the deck.
Nussy
Post by Nussy »
bailey86 wrote:one my realitives have a pontoon turned into a dock and cut a hole in the middle of it and droped a stainless steel tube from a washing machine in it and works great for a livewell would there be room for something like that
I've been kicking around a few live well/storage ideas below the deck but I couldn't think of a good way to do it that didn't involve something custom due to the aluminum plank decking. I was also worried about how deep they could be and stay above the water line. I then thought about a box above deck toward the rear for life jackets, anchor, battery, etc.
Bugpac wrote:Looking good, I think if it was me, I would weld a end across the c channel on each side, I use to build crest pontoon boats 20 yrs ago, seems like we did this to strengthen the deck.
I used stronger bracing than what Misty Harbor did on my 18 footer. I think it should be real solid, it's only 6 ft wide so the span between the pontoons isn't very far. I threw some plywood on to test the decking and it was really solid, it should stiffen up even more with the aluminum deck. Plus I plan to edge the top with 1"x3" angle(or possibly channel if it fits right) which would also firm it up a bit.
