ALUMA-JET- Duracraft 1648 SV Jetboat Conversion
- 9
Here's some photos of my project that I did back in 2005:
It began as a 1997 DuraCraft 1648 SV that someone painted with copper paint and left in saltwater. I bought it for 50 dollars
As you can see, this hull was severely pitted and corroded. However, the only place the corrosion went entirely through was basically along the center V of the hull. Everywhere else was just pitting.
So, I repaired the damage along the center V like so:
First modification-hatches for fuel tanks
For my next modification, I wanted a false bottom, with a layer of floatation foam between each set of ribs, along the sides, as well as the bottom. So, I made a false bottom out of 1/16" diamondplate, with the sides being 1/16" smooth aluminum. Foam:
False bottom installed: False bottom, looking toward stern. Notice there is a gap between the rear bench seat and the back edge of the false bottom. This is where I have to extend the rear bench seat for the length of the engine. That's next..............
ALUMA-JET project:
https://www.tinboats.net/forum/viewtopi ... 21&t=22023
Fishing, jet skiing, target shooting, jet-boating, and even a little oyster harvesting with Larry The Cable Guy.
Watch it all right here:
https://www.youtube.com/user/HKPSG1Shooter?feature=mhee
- 9
ALUMA-JET
OK, next step...extend the rear seat area:
I used some 16 ga aluminum sheet, along with some internal bracing, to make these extensions: One on each side:
Next, I made the engine cowling, using some 1/8" aluminum plate. I used that thickness, because I wanted it to be strong enough to walk on it: With all that done, it was time to build the console. I fabricated this from 1/8" aluminum plate, as well, because I wanted it to be stout.
Next, I decided that all wiring and cables should be routed above deck to the console, to simplify replacement or repair, but I needed a cover for the area where the wiring and cables crossed the floor, even though I planned to put it all inside of non-metallic watertight electrical conduit. So, this is what I ended up doing: With all the cosmetic work done on the interior, it was time to get busy installing the jet unit and the engine. That's next........
ALUMA-JET project:
- 9
ALUMA-JET
Mechanical time......this is where it gets tricky:
1998 Yamaha XL1200W pump
The point of no return.....getting ready to cut out the hull tunnel Notice the 1/4" plate now in place over the hull. The 2 will be tied together, to make the hull more rigid, and the plate will give me a place to mount my engine. Engine mount rails will fit in the slots along the sides of the 1/4 plate:
At this point, I now have to tie the hull together with the 1/4" plate: But keep in mind that the XL120 pump has a taper to its shape (of course it does, why would they make this easy?!) so, that shape had to be built in to the hull with a lot of welding, grinding, and cussing! Enough cussing to make a drill instructor blush. A real PITA, and I do NOT mean a type of bread!!
OK, now I had to build a tunnel box for the pump to bolt into:
Also had to have a 'horseshoe' shape to fit the intake scoop of the pump: That orange line you see is the waterline of the boat, tested with the amount of weight, distributed as it will be in the boat when completed. To find the waterline of any boat, simply dump some orange powdered chalk in the water and it will cling as a scum line to the hull, giving an approximate water line.
With this done, I bolted the pump in place, and made the mistake of using 5200 instead of RTV ultra black. NEVER, and I do mean NEVER, use 5200 on anything you don't intend to be permanent! I found this out the hard way then I had to replace this pump scoop after I burned out the thru-hull bearing by having the engine mis-aligned. Needless to say, it came out in pieces, and it was a PITA to get those loose. 5200 is some tenacious stuff! But I digress.
Pump bolted in: The next step was to install the engine...........
ALUMA-JET project:
- 9
ALUMA-JET
With the jet unit taken care of, it was time to get on the engine.....
Got a 1995 TS900 for 600 dollars, and it was a running ski! First step, pull the engine. Doing some initial measurements I wanted to have a rail design, while keeping the mounts as low as possible. So, the best way was to notch the tubing and inset the mount plates
mounts secured with carriage bolts
After notching the 2x 1/4" square tube, I used some 3/8" x 3" flat plate for the inset:
With the engine and pump now installed, I had to fabricate the fuel tanks, then start hooking up wiring, hoses, and cables.
ALUMA-JET project:
- 9
ALUMA-JET
For the fuel tanks, I used a factory made tank, but it had to be modified, because of the angle of the gunwale.
Anyhow, with all this done, I had to get to work on my controls.
For the steering, I used the heavier Teleflex CC694 series cable (I think they've changed the number to a '640' prefix now.) It's a stainless push-pull cable, with a 4" travel, and a 5/16"x24TPI end. I also used a teleflex jetboat steering helm, with the 270 degree turn radius. They also have a 135 degree, but I figured that would be a little too sharp, I wanted a little more room for error, I didn't want the steering to be over-responsive to movements of the wheel. So, that's why I used a 270 helm.
For the reverse gate, I initially used the flimsier CC633 series cable (that has 10-32 ends, instead of 5/16) but found that it would get bent under the thrust of reverse, and after replacing it three times, I went to the 694 series cable for reverse as well.
For the throttle cable, I bought some throttle cable conduit from a source online, and then I bought some 1/16" stainless cable from McMaster-Carr. For the throttle body and control handle ball ends, I used some 1/4" brass round stock, with a 1/16" hole cross drilled for the cable, and then on each end, I drilled and tapped for a #6 setscrew.
But I needed a control box. After looking around online and not finding what I wanted, I built my own. It's basic, it's simple, but it works.... The outer lever is for the reverse gate. The inner lever is for the throttle. Both levers have enough travel to accommodate the cable assemblies for full travel.
Then I had to fabricate a new wiring harness 20 feet long, to run from the console back to the engine.
Then I had to install the engine Upon completing that, I was ready for my test run!
I found out later that putting foam around a fuel tank is a bad idea, especially in salt water, as it sets up perfect conditions for crevice corrosion. The foam has since been removed, and the tanks now sit on risers made out of square aluminum tube, with rubber dampeners. Anyhow, with all this done, I had to get to work on my controls.
ALUMA-JET project:
- 9
ALUMA-JET
Needless to say, I was very happy to see my hard work pay off:
(Yeah, the guy wearing the green T-shirt in the mud with Larry was yours truly)
I've always thought my jetboat was cool, but I NEVER thought I would see it on national TV! When they showed it going through those oyster flats, I can't tell you the sense of pride that I felt. They had numerous other shots of the boat throughout that episode.
And yeah, it was pretty funny watching the camera crew and Larry scrambling around in pluff mud (if you aren't used to walking in the stuff, you can get stuck really bad, as seen on that episode)
And even more happy to be a part of something bigger, with my boat making its debut, as well..... From the History Channel show "Only In America" with Larry The Cable Guy, Episode-"Larry In Hillbilly Country" filmed Nov. 22, 2010 on location in South Carolina.(Yeah, the guy wearing the green T-shirt in the mud with Larry was yours truly)
ALUMA-JET project:
- 9
ALUMA-JET
Like what you see so far? Want to see more? How about a series like "American Chopper" except, geared towards jetboat building?
Check out my youtube channel, there are a lot of videos of the Aluma Jet, both in it original version from 2005, and now in its new High Output 4 stroke configuration, just this past year.
I also have 2 "seasons" of my series I call "American Jetboat" Season 1 is the original build, back in 2005. There are 3 10 minute episodes of season 1.
Season 2 is called "High Output" and that was done this past summer. The old Tigershark engine died a horrible death after some POS with no CFC (common friggin' courtesy) in a para-sailing boat swamped me with a 3 foot wake, and blew the engine up, so, it was replaced with a Yamaha MR-1 High Output engine. There are 6 10 minute episodes of season 2.
Check it out at:
Check it out at:
ALUMA-JET project:
ALUMA-JET
Wow that is pretty amazing! What a boat find as well and you did one the best builds ive ever seen! I sure would like to build one of these jet jons but they sure seem like alot of work if youve never done it before!
More pictures of any other builds would be great! Also where did you get you switches?
Thanks and great job!
Force from Above!
- 9
ALUMA-JET
Yeah, they are a lot of work. You pretty much have to have your own welding and machining equipment, and the know-how to fabricate and design.
If you had to pay for a welder and a machinist to do all of this, you'd go broke real quick!
As far as my switches, they are regular toggle switches I picked up at west marine, they are the type with the illuminated tip. The switch is wired to the ignition circuit, so when the boat is running, all switches glow white, unless turned on, then they glow red. Looks pretty cool at night. Also, I replaced all of the bulbs in my gages with LED's, to minimize power usage at night.
The labels you see mounted around the switches, I fabricated, by cutting thin strips of aluminum, and then using a letter stamping set, then securing them with 1/8" rivets. The switch labels and the control handles have since been changed out for bronze counterparts, to dress it up a little.
ALUMA-JET project:
- Moderator
ALUMA-JET
Looks like a good fuctional build. I certainly is a good feeling to see your hard work earn some recognition. Your boat is about the same size as mine now. How much better is the high output engine vs. the old tigershark? I guess if my Seadoo engine ever dies I'll look at getting a water cooled street bike engine and mounting it in the hull.
Jamie
Jamie
My Seadoo Powered Bass Boat https://www.tinboats.net/forum/viewtopi ... =21&t=8385
YouTube channel https://www.youtube.com/user/ranchero50
- 9
ALUMA-JET
Ranchero50 wrote:Looks like a good fuctional build. I certainly is a good feeling to see your hard work earn some recognition. Your boat is about the same size as mine now. How much better is the high output engine vs. the old tigershark? I guess if my Seadoo engine ever dies I'll look at getting a water cooled street bike engine and mounting it in the hull.
Jamie
Yeah, like I said, I've really enjoyed this boat, I've had more fun with it than with any boat I've ever owned, including the Sea Doo Speedster jetboat.....at idle, it had about 2 feet of draft, it could never go into the areas that the aluma-jet will travel. And then to see it on the History Channel was just awesome, knowing that it was a boat that I built from scrap into what it is.
My hull is 16' 4"...and then I have the platform on the transom, so, total length is probably about 17' 6" or so.
As far as how much better is the High Output than the Tigershark, I can't even begin to describe it! If you check out my youtube channel, there's a video showing the sound levels of the 2 stroke and the 4 stroke engines in this boat. And then I have a video showing the hole-shot, where I blast a 18 ft Sea hunt outfitted with a 150 Mercury Optimax. Granted, the Sea Hunt has the top end, but out of the hole, the High Output rockets past the Sea Hunt. Top end of my boat is about 10 MPH faster than the Tigershark, and I think I could probably get that higher if I experimented with impeller pitch. Right now, I'm running a 13/19 Concord swirl impeller, which gives me a lot of hole shot, but I think may be limiting my top end somewhat.
The difference between the 2 and 4 stroke is very noticeable. Ya know how when you rev up your 2 stroke jet ski engine out of the water, how it winds up to a high RPM, then slowly winds back down, with the familiar pop-pop-pop as it winds down? None of that with the 4 stroke. The second you bump the throttle, it responds, there's no lag to it. And the RPM winds back down instantly, there's none of that lag like with a 2 stroke.
There's no smoke, either, as it's a 4 stroke. So, no gagging on fumes while idling with the wind on your stern.
It's also much quieter, being a 4 stroke. Also, if you check out "American Jetboat High Output Part 3" you see that we have taken out the original jet unit tunnel, and made it 4 inches wider, which gives room for the exhaust to run into the tunnel. On the Tigershark, we had the exhaust running out the back of the boat. Yamaha routes the exhaust through the tunnel, as we did, and that also helps to quiet down the sound signature. The platform on the transom also helps to muffle the noise.
And it seems to be better on fuel consumption...roughly 3 gallons per hour, or 5 MPG, is what I'm getting with the HO engine, with 2 people on board.
The High Output is also equipped to carry weight better. The Tigershark was a 2 person jet ski, the HO engine came out of an AR-230 jetboat. These boats have 2 engines, and the boat weighs 3000 pounds empty, then its capacity is another 1800 lbs, for a total of 4900. Divide that by 2, because there's 2 engines, and you come up with 2450 lbs max load for each engine. My boat might weigh 1000 lbs, so, that gives me another 1450 lbs before it's totally maxed out on weight.
As far as a water cooled street bike engine.....that's what the MR-1 High Output is. It is the marine version of their R-1 motorcycle engine. These engines are actually designed to run at 14K RPM sustained. The HO engine runs at 10K RPM, so, it's not even maxed out. It also uses a 1.47:1 reduction gear which steps the impeller's top speed down from 10K to about 7,400 RPM, as the average jet pump can't sustain that kind of RPM without damage to bearings or thru-hull seals. not to mention once they reach a certain RPM, they will actually begin to lose efficiency.
If I do another jetboat build, I'm probably going to use a Sea Doo 4tec intercooled supercharged 215 HP engine. With the closed loop cooling system, you never have to worry about sand or mud clogging it and running it hot, nor do you have to flush it every day you use it in salt water, you could leave it tied up at the dock a couple of days, with no ill effects (as long as you have galvanic protection of your hull and jet unit with a lot of zinc anodes)
And just a side note FYI, a 16 foot johnboat needs about 36 sq inches of zinc for proper galvanic protection in saltwater. In freshwater, instead of zinc, you use magnesium anodes for protection. Because the bottom of my boat had some pitting, one of the first things I had to do was to sandblast the entire bottom with a 60/90 grit of 'Starolite' blasting media, to remove every trace of that copper paint. Then, the entire bottom was painted with a 2-part polyamide epoxy (submarine paint) to seal the pitting. Then a coat of Copper Thiocyanate paint every year, for antifouling. (Copper Thiocyanate for aluminum boats, Cuprous oxide for fiberglass.....NEVER use cuprous oxide on aluminum, it will destroy the boat!!)
But, six years later, a lot of that paint is wearing out, so, I plan on having the bottom sprayed with Line-X truck bed liner. The guy told me that it can actually be applied with a surface as smooth as paint, the texture you see in truck beds is created by standing back from the surface to spray the coating. I know a few people that have had their hulls done like this, and I'm probably going to do the same in the next few months. This would give the hull some long-lasting protection.
At any rate, I enjoyed the thread on your boat build, as well. Reminded me of the long process I went through to do mine. Lots of long days and long nights, and a lot of trial and error, and going back to the drawing board. Heck, my girlfriend was about ready to file a missing persons report on me, I was spending so much time in the shop....LOL
And it seems like every time I say "it's done"....I find yet something else to improve or change. Seems to be a never ending work in progress, always changing and improving.
ALUMA-JET project:
- 9
ALUMA-JET
Thanks for the compliments! Definitely a fun boat, and it works great for fishing and flounder gigging, too!
When I initially built the boat, I knew it needed a stomp grate, but I got by for about a year or so without one. Then, I got something fouled in my intake grate on the river one day, and had to idle about 5 miles back to the landing. So, I knew it was time to make the stomp grate.
Having owned a Sea Doo Speedster, I was familiar with their design, and wanted to incorporate something like this on my boat. So, I ordered a few of the parts from Sea Doo. Specifically, the tapered rubber bushing, and the 2 plastic half-collars that clamped the cable in place in the thru-hull fitting. I also ordered the plastic nut for this assembly, as well as the cable end fitting to attach to the weedless grate.
However, I was not able to find that wedge-shaped piece of aluminum with the internal threads, that bolts to the top of the intake scoop, for the cable to fit into. I looked for a while, and then decided to just make my own.
Also, I found that the plastic nut from Sea Doo was not an NPT thread, it was some screwy thread, I have no idea what pitch it was, or if it may have been a metric pipe thread.
So, I tossed that part aside, and instead used a plastic 3/4" NPT plug, drilled a hole in the center for the cable to fit into, and then shaved a little bit of material from the inside, for the plastic half collars to fit in.
Also, I had to make the threaded thru-hull fitting, with 3/4" NPT threads for the plug.
So, I proceeded with some large diameter solid round aluminum, and I contoured the bottom of it so that it would fit the top of the intake scoop, and be perpendicular, not skewed to the side.
I center drilled it for the diameter of the cable, then, I machined a taper in it, to fit the taper of the rubber plug, and finally, I cut 3/4" NPT threads.
Next, I had to have a way to secure it to the intake scoop. So, on the bottom side of this block of aluminum, I drilled and tapped for 1/4" threads.
Because of the contour shape on the bottom of the block of aluminum, it had to be positioned a certain way to remain perpendicular, but how to do this AND get the correct location for those blind holes?
Simple.....I took a couple of 1/4" stainless screws, cut the ends off, then ground them to a sharp point. I threaded the blunt end into the threaded holes of the aluminum block (basically, I made a set of transfer punches) I positioned the block of aluminum where it needed to go, then gave it a light tap with a hammer, and I had my locations for my mounting holes.
Using RTV ultra black, and some taper-head phillips stainless 1/4" screws from the underside of the intake scoop, the block of aluminum was secured in place. Then the cable assembly was installed with the locking half collars, the rubber bushing, and the 3/4" plug cap, with RTV applied to the tapered end of the rubber plug, as the sea doo manual calls for.
Once it was done, this is what it looked like:
A few shots of the thru hull fitting, with cable installed, you can see RTV used to seal under the fitting, as well as the 3/4" NPT plug. A shot from the underside, showing the mounting screws:
Also note the cable end.
Next, I needed to make the intake grate pivot. I cut all the tines loose from the factory aluminum grate. I kept the front end of the assembly. Next, I took some 3/4" round stock, and cut 3 pieces about 1/4" thick from this. Then I welded these 3 pieces onto the front flange of the intake grate, one on each side, and one in the center. This would create a pivot point.
Then, I took some 1/4" thick by 3/4" wide stainless flat bar, used the belt grinder to remove the corners and do some shaping and rounding of edges, and made 4 new tines, and drilled a hole at the back end of one of them for my cable end.
Lastly, I needed a control lever at the console for operating the grate. Using the same concept as the reverse gate lever, I came up with this: As you can see, this lever is bronze, as are the other control levers. To operate, cut off the engine, then swing the lever down. This pushes the back end of the intake grate down by about 4", allowing debris to clear itself. Return the lever to its upright position, and it retracts the grate. Once all of this was done, I performed a watertight integrity check (fill boat with water until it's above the area you want to check for leaks) and found it to be OK, no leaks.
Works like a charm, and it's simple to operate!
ALUMA-JET project:
