First Project
JBooth
First Project
Post by JBooth »
Hello, I am new to this forum. This was my project over the summer. It's a 1970 Duracraft.
Enjoy and feel free to comment.
First coat of paint
First coat of paint
First coat of paint
First coat of paint
Put in floors and back deck. I cut 2 pieces of 2 by 4 and bolted them into the transom for the back deck deck support. I then drilled I by 2" marine wood for support across from the transom to the bench seat.
Back flooring
Back flooring
Front floor & Trolling motor I got. It's a '07 minn-kota 50# thrust.
I got a motor for it. It's a '96 Force 15hp that runs flawlessly.
Here she is. At this point it's pretty much finished.
I installed a Lowrance Sonar/Fish finder. I got it for $25 from a yard sale. It had never been used. I got it home and found the receipt; the guy originally paid $560 for it.
I cut a piece of treated 1X4 and bolted it above the waterline of the transom. Then installed the Sonar and speed measurer on it.
Firescooby
First Project
Post by Firescooby »
Looks good, I wish I could find an outboard like that.
I've read that you don't wanna use treated wood with a tin boat because of the high copper content.
19something PolarKraft SV-1448L
2006 Chevy 2500HD 4wd CC/SB Dura/Alli
2005 Forest River 30' Fifth wheel
Wonderful wife and two beautiful daughters (7 and 2)
JBooth
First Project
Post by JBooth »
Thank you!
If you dont use treated, the wood will just rot right? What is the other option?
crazymanme2
First Project
Post by crazymanme2 »
I used a piece of aluminum 1/4" thick & wide enough to mount transducer on.I just fastened on the top so no holes where below the water line.
Nice job on your tin & welcome aboard =D>
Craig
Be Who You Are
And Say What You Feel
Because Those That Mind ....Don't Matter
And Those Who Matter....Don't Mind
JBooth
First Project
Post by JBooth »
Thank you! I appreciate the information.
Turbo7
First Project
Post by Turbo7 »
I used standared 3\4 plywood and put about 4 coats of spar urathane on the wood.
Firescooby
First Project
JBooth wrote:Thank you!
Like said before, use the Spar urethane.
JBooth
First Project
Post by JBooth »
Thanks for the information I will look into that before I do anything else.
jasper60103
First Project
Post by jasper60103 »
I used a piece of composite.
2018 Tracker Grizzly 1648
BaitCaster
First Project
Post by BaitCaster »
Nice job! I used a plastic mounting plate (purchased from Cabela's) to mount my transducer.
“There’s a fine line between fishing and just standing on the shore like an idiot.” ~Stephen Wright
The Livin Large Project - https://www.tinboats.net/forum/viewtopi ... 21&t=14160
