V Hull Build
ky_madman
V Hull Build
Post by ky_madman »
Well,
I've started the rebuild of my 14ft. 73' Starcraft V-Hull. This boat hadn't been moved in 4-5 years and was in desperate need of a make-over. Here's a few photos of what's been done so far. This site has been the inspiration for this build. Since this build started, I bought a bigger bass boat for Lake and big river fishing, so this will be used, mostly, in a electric-only reservoir. I'll rebuild & keep the 20hp Chrysler...just in case. Thanks for all of the input from the members here :D
This is what I started with
GULF WAR VET. DISABLED AMERICAN VETERAN member of DAV,VFW, AL
Please Support "OPERATION INJURED SOLDIER"
https://www.injuredsoldiers.org/
ky_madman
Post by ky_madman »
Here's a few more photos
Here's the shell, cleaned out ready to start. You can see the 20hp Chrysler on the transom.
This is my 15 yr. old son applying the duplicolor bedliner.
Nice Start! Looks much better with out all the stuff in it! :D
Please use our Amazon Affiliate link. It costs you nothing and sends a few cents to the site.
ky_madman
Post by ky_madman »
few more photos
Checking New Seat Fit
Used Aluminum Angle iron for the supports
Front Decking
Front Deck after primer, awaiting Carpet
Trolling Motor Mount - Bottom
Trolling Motor Mount - Top
Fresh Paint
Once it starts to all come together, I'll take more detailed photos. I'll also take some outside of the paint, once the weather improves.
GatorTom
Post by GatorTom »
Looks great. I decked a 16' Starcraft that looks a lot like yours last year.
Here's the share-a-project that I did on my rebuild.
https://www.shareaproject.com/pages/pro ... 45,00.html
Post by Waterwings »
Great work Ky Madman and GatorTom! 8)
ky_madman
Post by ky_madman »
Thanks Waterwings. I'm using the same carpet as you.
Great Job Gator! It funny how similar our builds are shaping up to be. I ran pvc for wiring too, and used the seats to brace the decks. Very nice boat you've got there!
ky_madman
Post by ky_madman »
Can't hardly beat the price of that Lowe's marine carpet, and it's not bad stuff either. :)
ky_madman
V Hull Build
Post by ky_madman »
Been kind of slow lately, but I have a question. I'm putting in a cooler-type livewell. How do I run the drain? Can I "T" it in to the bilge pump hose? Any and all suggestions are appreciated.
GatorTom
V Hull Build
Post by GatorTom »
I have a pumpout drain in the bottom of my livewell and an overflow drain towards the top that are T'd together with a one way valve for the overflow. Mine's towards the front and I didn't want to run hose all the way to my bilge pump outlet. So I ran another outlet out of the side above the waterline.
ky_madman
V Hull Build
Post by ky_madman »
Thannks for the info. I'm getting ready to add some new photos of the build-up.
ky_madman
V Hull Build
Post by ky_madman »
Although I'm not done with the build, it was time to put it on the water...That means time to go fishing!
From This
To This =D>
My oldest son's first fish of the year. The bite was slow, I guess because of a cold front, but still a good day on the water.
V Hull Build
Good day fishing! =D>
How did the boat do the first day out with what you have done so far?
ky_madman
V Hull Build
Post by ky_madman »
It did great! Hopefully I can give it another test ride this evening....If I can get my lawn mower going and cut some grass. Guess I should have been working more on the lawn mower and less on the boat. But a man has to have his priorities in line.....when the fish are biting and turkeys are gobbling, cutting grass can wait.
