TinBoats.net's Least Exciting Mod! Alumacraft 1648 NCS
Chub Tub 2.0!
Okay, this was probably one of the most straightforward mods ever done, so unfortunately I can't offer you anything too exciting, sorry.
Highlights:
Floor is 3/4" marine grade ply with cut-in-half pool noodles underneath.
Aluminum sheeting between the ribs to smoothly transition the wood to the hull and to stash things against the sides and out of the way.
Casting deck is 1/4" AB ply over the factory aluminum deck.
Rear bench has a 30" SliderG5 that I surrounded with 1/4" AB to finish off the look.
Stacey from Warner's Dock got me the seat pedestal box and trolling motor bracket from Alumacraft. Seat box easily holds a DC27 battery and has room for other stuff if need be.
Dual Marinco trolling motor plugs
Cabela's Premium Carpet
Berkley rod holders
I decided on an open floor plan for versatility, but mainly I wanted to have some sides for when my young kid is aboard. Wise seat spider or padded cooler in the middle works for the 3rd man in and I can easily fit my Kamp-Rite IPS tent for an on-water, overnight excursions.
Yes, I put the registration stickers on before the #'s instead of after because I'm a rebel.
Highlights:
Berkley rod holders
Nice job. I like rebels....hell I am a rebel from Texas......
1984 14 Deep Fisherman Mirrorcraft
https://www.tinboats.net/forum/viewtopic.php?t=23315
- Moderator
I like simple and straight forward.
Nice job. I'm sure you will enjoy it for a long time.
Nice rig Butthead
I haven't seen the NCS with a flat front until yours, I like it! The seat pedestal box is an interesting addition, let us know if you like it in that location in the long run. From the pics, it appears you are running electric only, do you have an outboard? Also, Tennessee requires the stickers to be placed closest to the bow, so your legit down here!
I was pretty happy I went with the NCS when I took it out the first time. I love being able to stash the rods on the sides and I like how much floor space I have to sprawl out my gear. I do think I may try to find/buy/build a lightweight,aluminum table to put over the batteries so I can have my gear directly behind me instead of on the floor.gillhunter wrote:I like simple and straight forward.![]()
I REALLY like the seat pedestal box. Plenty of room with it up there and I like having the battery below me for more forward weight since this is an electric only rig.Ictalurus wrote:Nice rig Butthead![]()
I also use a wide-butt/leaning casting seat instead of the full seat which is a little nicer when standing. My buddies is talking me into getting a recessed foot tray, so that will come down the line. Eventually I'll get an outboard but it's not a priority at this time.
- 9
very nice! i have a 16 ft boat as well. I also bought the cabelas carpet too. Couple questions:
How did you attach the carpeted pieces of wood to the side ribs that the rod holders are connected to?
how did you secure the forward and aft plywood to the boat?
thanks!
thanks!
1996 Voyager 70 Series 16ft jon boat, 1979 Evinrude 35hp
https://www.tinboats.net/forum/viewtopi ... 21&t=29553
- 9
Sorry, dumb question but what does NCS stand for?...Ictalurus wrote:Nice rig Butthead![]()
MNHunter505 wrote:Sorry, dumb question but what does NCS stand for?...
NCS is No Center SeatMNHunter505 wrote:very nice! i have a 16 ft boat as well. I also bought the cabelas carpet too. Couple questions:
thanks!
I couldn't mount the rod holders directly to the rib because of the location of the mounting holes, so I had to use the wood bases.
First I screwed the top of the holder into the wood. Then I screwed the wood into the rib as high as I could, which is about 1/2 to 2/3 the way up since the rib starts to bend outward. Then I put the bottom screw through the holder mount, through the wood, and into the rib. It's holding nice and tight but the screws are easy to access if I ever needed to tighten it down again.
I use Deck Mate Evercoat exterior screws with lifetime guaranty.
Screw right through the wood into the aluminum deck in strategic spots and into the ribs on the aft deck.
They hold really tight to the wood, and aluminum, and should stand up to the weather well. I keep my boats covered so they won't really see a lot of water anyway.
Just to give a little idea of the durability, I had attached a piece of square aluminum tubing to a piece of wood that wound up sitting outside for about 4 years. When I took it apart to salvage the tubing, the screws came out still looking new. I felt very confident with them after that.
Your mod looks factory done! Dont underestimate your fine workmanship!
Sylvan 1978 Seabreeze 1453, '78 Evinrude 9.9, Motorguide R3, Pflueger Trion GX-7
https://www.tinboats.net/forum/viewtopi ... 21&t=25479
Big fan of NCS. The floor space is amazing. I really like the way you mounted the rod holders. I might have to try something similarly with.
Alumacraft 1648 NCS
https://www.tinboats.net/forum/viewtopi ... 21&t=26396
- Moderator
+1 Looks very nice. Simple, clean and most important...functional to your needs!
2011 TinBoats/BYOB Labor Day Tournament Champion
Sorry to necropost an old thread but I had a question. First I agree with you on the open floorplan. I keep mine the same way. Nice job on the mods. The question. How is the floor held down over the noodles? The carpet looks like it wraps around the plywood so Is it glued down or did you screw it down before carpeting and just do a real nice job carpeting?
Thanks for posting.
Kenny
Thanks for posting.
Kenny
If a man is too busy to fish, can he really be considered a success?
- 8
Man I have been looking everywhere for a box like that to mount my front seat on, where did you find it? I have found a couple of fiberglass ones but I really want to go aluminum.
Thanks
Thanks
https://www.tinboats.net/forum/viewtopi ... 21&t=33083
Tracker PF 16 PANFISH
- 9
Alumacraft.
TRACKER 1542 LW sticksteer [BREAMREAPER]
I glued the carpeted down after the wood was installed so that you wouldn't see any screws. The wood is screwed directly to the ribs and I want to say I used 17 screws in total 4-3-3-3-4. Between each rib on both sides, I used thin aluminum and bent it at a downward angle. I did this to fill the voids while also creating a space where stuff can sit nicely without it rolling around on the deck and if something small gets stuck down there, you can push down on the aluminum to easily get it out of the way to retrieve the item without messing up the aluminum.
I purchased the pedestal box from Warner's Dock:
Part number: 2-03-002-3238
Stacy Warner
Parts/Accessories & Warranty
Warner’s Dock Inc
888/222-3625
https://www.warnersdock.com
Here's the link to that page with description and part number:
https://www.warnersdock.com/ABCPandA/ABCJonSeats.htm
When I ordered, she said I had the option of grey or green.
Stacy Warner
Warner’s Dock Inc
888/222-3625
