IDAHOAUGER's New Lowe L1436 Conversion
IDAHOAUGER
Post by IDAHOAUGER »
Open gas/battery compartment.
Many men go fishing all of their lives without knowing that it is not fish they are after. - Henry David Thoreau
If people concentrated on the really important things in life, there'd be a shortage of fishing poles. ~Doug Larson
Lowe L1436 Jon Boat Project
https://www.tinboats.net/forum/viewtopi ... 21&t=27828
Zum
Post by Zum »
Nice job on your boat.
I just want to say(this might be overkill)have you thought about moving your battery forward in the boat?
Is your motor electric start and the battery for a bow trolling motor?
Only reason I ask this question is that gas fumes are heavier then air and maybe they could get trapped in the opening you made...a spark from the battery terminals and o oh.Like I said maybe I'm overthinking this,it is open to air.
What are other people doing,battery in same compartment as fuel?
spotco2
Post by spotco2 »
You don't have to worry so much about that since the compartment is completely open.
All of my bass boats had batteries and gas tanks under a closed hatch that was vented. As long as it's vented, you're good to go.
inlovewithsurfin
Post by inlovewithsurfin »
my fuel tank and battery are in the same back hatch and under a cover with a slight opening and havent had any issues....
IDAHOAUGER
Zum wrote:Nice job on your boat.
The battery is for the trolling motor but I will likely move the trolling motor forward due to mounting issues anyway.
IDAHOAUGER
spotco2 wrote:You don't have to worry so much about that since the compartment is completely open.
Thanks! Good to know, I figured it would be OK having both in an open compartment.
IDAHOAUGER
Thanks! I think I will also add a fire extinguisher back there as well which is not required for my type of boat but I think it's a good idea.
spotco2
Post by spotco2 »
Anytime you have gasoline onboard a fire extinguisher is a good idea!
IDAHOAUGER
I added a portable Lowrance fish finder which uses a scuction cup transducer and can be moved around as needed. I also would like to try it using the same unit during ice fishing season.
IDAHOAUGER
The deck between the center bench and front deck is for mounting an elevated bass boat style seat and to have additional storage below. I wanted this section to just drop into place so it can be lifted out and removed for cleaning or just not having it in place for a given trip if I choose not to have it. Here is the basic 2x4 framing which will rest on the ribs and the deck floor will be mounted over this and fit by butting up against the sides of the boat. The one photo shows cardboard below the frame since I had water sealed the wood and wanted to avoid contact with the aluminum until I placed carpet under the supports.
IDAHOAUGER
For the front elevated seat deck, I cut out the basic shape using a jigsaw and then used a belt sander to clean up the edges and get it shaped more percisely. Once I got the floor mounted to the 2x4 frame I marked off the location of the storage hatch and the seat pedestal where the 2x4 framing below would also be used as the lips for the storage hatch and the seat pedetsal bolted into the 2x4s.
IDAHOAUGER
Cut out the storage hatch opening and after doing the water seal I put the carpet on the deck. I did not mention this before, but I find a baking rolling pin to be perfect for smoothing the carpet over the adhesive glue.
IDAHOAUGER
Seat pedestal installed and dropped into place in the boat.
IDAHOAUGER
Storage area and hatch.
IDAHOAUGER
Added a simple latch from Lowe's.
