My project
seaarc
My project
Post by seaarc »
Well here are some before pics of the MV1448 Sea Arc I plan to modify once I finalize a floor plan.
Dave
Image Image Image Image Image
My project
Post by Captain Ahab »
That boat will make a great project - looks good
My project
Killer boat dude! Love those Hondas! :beer:
What are those straps on the sides of the seat?
My project
Post by Waterwings »
Nice rig, seaarc! 8)
You take it out of state a lot? I noticed the plates on the trailer.
seaarc
My project
Post by seaarc »
The straps are rod savers. No I just got the boat 2 wees ago and the plate was already on it.
alumacraftjoe
My project
Post by alumacraftjoe »
Nice rig... it will make a great conversion!
Joe Maione
Jeffersonville, IN
https://jigsbyjoe.blogspot.com/
seaarc
My project
Post by seaarc »
Well I made the plunge and cut out the center seat today. So I guess this project is under way. Has anyone used the roll on bedliner on the inside of the hull? If so will this quiet down the hull any at all? I looked for it at Lowes tonight but they don't carry it. Who does?
Thanks Dave
My project
seaarc wrote:Well I made the plunge and cut out the center seat today. So I guess this project is under way. Has anyone used the roll on bedliner on the inside of the hull? If so will this quiet down the hull any at all? I looked for it at Lowes tonight but they don't carry it. Who does?
Thanks Dave
Walmart sells it. It will work, but it soaks up the hot sun like no ones business. I put it on all my pickups.
seaarc
My project
Post by seaarc »
Thanks Jim it will be covered with a plywood floor and carpet so that wont be an issue.
Dave
GatorTom
My project
Post by GatorTom »
Instead of bedliner, you could put foam under the floor to help deaden the sound. I've seen a lot of guye use that pink insulation foam from Home Depot. Just a thought.
seaarc
My project
Post by seaarc »
I wonder if this stuff is closed cell so that it don't absorb water? I had planned on cutting up the foam that was under the middle bench I cut out and spreading it out in the floor. I was wanting the spray or roll in bed liner for it's waterproofing effect also.
Dave
phased
My project
Post by phased »
That is the type of foam I am using on my jon. I was concerned about it being closed cell so I weighted down a piece in a bucket of water for several days. No water absorption.
Ouachita
My project
Post by Ouachita »
GatorTom wrote:Instead of bedliner, you could put foam under the floor to help deaden the sound. I've seen a lot of guye use that pink insulation foam from Home Depot. Just a thought.
No direct experience, but from what I have read that pink foam is not gas resistant. It will turn into a pink goo under your floor if you spill some gas in the bilge and it get washed into contact with it.
Genesis 1:26a Then God said, "Let Us make man in Our image, according to Our likeness; let them have dominion over the fish of the sea...
seaarc
My project
Post by seaarc »
Thanks phased. That's interesting Ouachita never thought about gas contact.
Dave
firefighterfree
My project
Post by firefighterfree »
I have experienced the pink foam not being gas resistant, But in order for it to turn to goo it would have to be submerged it gas. I personal is currently using the pink foam. Honest is there ay foam ou there that is gas resistant. My experience and 2cents
