My project
DenisD
My project
Post by DenisD »
firefighterfree wrote:
Ouachita wrote:
GatorTom wrote:Instead of bedliner, you could put foam under the floor to help deaden the sound. I've seen a lot of guye use that pink insulation foam from Home Depot. Just a thought.
No direct experience, but from what I have read that pink foam is not gas resistant. It will turn into a pink goo under your floor if you spill some gas in the bilge and it get washed into contact with it.
I have experienced the pink foam not being gas resistant, But in order for it to turn to goo it would have to be submerged it gas. I personal is currently using the pink foam. Honest is there ay foam ou there that is gas resistant. My experience and 2cents
There is foam that resists gas, I think it's polyethylene? I'm thinking it's the stuff that those swimming pool noodles are made of. I had bought a sheet of it for a jon boat flooring project but sold the boat instead. #-o I had to go to a speciality foam place I found online. I think you could even get different densities to support more or less weight. Try looking up foam sheet online or even in local phone book.
seaarc
My project
Post by seaarc »
update :
Image Image Image Image Image
tholdah
My project
Post by tholdah »
Nice boat...WICKED AWESOME MOTOR! (ya...Massachusetts). Anyway, I'm curious to understand all the hubub over sound proofing/insulation? I've never noticed excessive noise on my prior jon boat, and I'm not recording my debut album on the lake...so what's the concern? :?
My project
I used to fish with a buddy that had a bad habit of dropping things in the boat at the worst times. You pull up to a killer cove and he drops his pliers. #-o
Free Decal? Click here to get one!
kemical
My project
Post by kemical »
seaarc wrote:update :
OMG,, I WANNA SEE THE FINISH END RESULTS!!!lol please post
https://www.facebook.com/tcmdoc
Tampa, fl
IN THE HUNT LOOKING FOR A JON!!
FishingBuds
My project
Post by FishingBuds »
looken good, the bedliner works on the inside not the underside :D
2TIM 4:7 I Have Fought the Good Fight, I Have Finished the Race, I Have Kept the Faith.
My "1973" 1436 custom jon link!
seaarc
My project
Post by seaarc »
Yea I decided against the bedlinner.
seaarc
My project/update
Post by seaarc »
Got most of the framing complete and sealed starting to cut the plywood for the flooring and decks. I'll post some pics later.
seaarc
My project/framing pics
Post by seaarc »
Ok here are the framing pics so far.
It will have four storage compartments and fishing seat up on front deck. A rod locker that will hold a 7' rod easily. A seat pedistal down low on the floor for use while powering :lol: across the lake. And a deck across the back bench with access to gas tank and battery. Up against the front deck there will be a box for battery and some storage and across from the rod locker there will be a livewell of some kind ( still figuring this out). Question is when will I get to go fishin!!!
Thanks for checking it out
Dave
Dave Deutsch
My project
Post by Dave Deutsch »
The progress on this one really makes me want to redo mine just because I have some new ideas. I think for now I'll just fish out of it and prepare for the next one. A 1966 G3 w/90 hrs Yammi. I've got all kinds of ideas for that one. Just need to save for a few more years before I can have her!
Great job on the boat so far!
New Rig 20ft Lund Alaskan, Yamaha 70 horse 2 Stroke, Yamaha 8 horse 2 stroke
Old Rig 2003 Xpress 1650VJ - 2003 Mercury 25 horse 4 Stroke
Quackrstackr
My project
Post by Quackrstackr »
Are you guys saving your pennies to reprop after adding all of this decking and framing? :shock:
You may find that you need to drop an inch or two in pitch to get back some performance.
Paddle faster... I hear banjos
seaarc
My project
Post by seaarc »
What performance? It's only got an 8 horse on it now. The sticker says I can go up to a 25 horse so once all the mods are done I will decide if I need to go with more horsepower or just live with what I have.
Dave
Quackrstackr
My project
I guess that I was just typing out loud.
I see a lot of pics of a lot of weight being added to boats on here with little mention of what issues may arrive after the fact.
With an 8 horse you probably weren't setting any water speed records to begin with, which may make it even worse in your particular case. Just throwing it out there.
seaarc
My project
Post by seaarc »
Shoot I'm hoping it at the least helps the boat get on plain. Right now I go down the lake with the nose in the air.
Dave
My project
Framing looks awesome man! =D>
