My Walleye Project - 70's Sea Nymph SS160 1668
jvanhees
Post by jvanhees »
Getting some foam in and starting the floors
Here you can see where the PO cut out the rear deck support, cut out the rod protector, and cut out the side console. All cutting could have been avoided by drilling out rivets ](*,)
I think for the sake if finishing the project (the starcraft resto is on my mind now....) I may make it a tiller. Depends on what I can find for a motor at bottom feeder prices.
1668 Sea Nymph SS160 - Current build
https://www.tinboats.net/forum/viewtopi ... 21&t=29791
1868 Landau Mod-V - Sold!....to fund SN
https://www.tinboats.net/forum/viewtopi ... =9&t=29763
rscottp
6
Post by rscottp »
Good looking project, its coming along nicely.
jvanhees
Post by jvanhees »
Ok so heres the update....I had twin girls Feb 20th, so all of 2014 has been twin-voloved with them. :LOL2:
I picked up my third boat in 9 months....
Unsure of the year, but its an aluminum hull Duratech!
Bought it for this specifically, with its steering and controls. 1978 50hp Johnson. 119 and 125 compression in the cylinders. Power head coloration was perfect. Spark plugs looked normal. Fired up for a few seconds after using some brake clean in the cylinders last night....so it runs. Will be doing an overhaul on this on the necessities.
jvanhees
Post by jvanhees »
Picked up a third boat. Donor! 16 ft alum Duracraft
jvanhees
Post by jvanhees »
Got the motor out with all steering components. 4 nice seats and pedastals. 2 oem metal gas tanks. Lowrance FF. A paddle, map of Lake Erie fishing spots and maybe another thing or two. Paid 350 for everything and sold the empty boat and trailer away for 200. Made out pretty good.
And in the meantime got a new transom covered in spar in the SN
jvanhees
Post by jvanhees »
Warmed up a tad one weekend and I wanted to have some rewarding progress done, so I painted the hull. Rusto SE primer followed by rusto marine topside/catalyst hardener.
jvanhees
Post by jvanhees »
Now I have the floors cut along with the casting deck. Going with carpet and going to hit the interior of the hull that will show, with some SE primer as it looks nasty right now
What type of glue do you guys use to put the carpet down??
The light grey is SE primer, dark is carpet. Thoughts?
rscottp
6
Post by rscottp »
I like the color scheme. I see your dogs are helping with the spar!
jvanhees
Post by jvanhees »
rscottp » Today, 12:38 wrote:I like the color scheme. I see your dogs are helping with the spar!
Thanks Scott! Those potlickers help with moral support!
adam_mac84
1
Post by adam_mac84 »
I have a similar style Sea Nymph that I hope to get a deck in. I am curious about water flow/drainage under your foam. These boats don’t have recessed channels for water to flow toward the back. Do you find problems with water getting stuck?
gillhunter
Post by gillhunter »
Welcome to the forum!
The OP hasn't been on the site for 3 years so I doubt that you will get an answer.
Tip for the new members. When researching old threads check out the OP's profile to see if they are still active if you want to ask them a question.
