12' mod-v Bluefin remod.....First one....FINALLY FINISHED!
dambo0708
Post by dambo0708 »
Well guys just finished my first tin! Took me longer than planned but its ready for the camping season now. No motor yet but trolling motor works just as well for bass fishing. Here's some before and after pics.
Nate Dembowski
1975 Bluefin 12 ft v-hull. Finished May 2013!
https://www.tinboats.net/forum/viewtopi ... 55&start=0
dambo0708
12' mod-v Bluefin remod.....In Progress!!
Post by dambo0708 »
Didn't get a lot more done. My buddy was supposed to bring me a jigsaw and never showed.
Nate Dembowski
dambo0708
Post by dambo0708 »
I guess no one is following....lol. I don't know why some of the pics are upside down. Doing this all from an Iphone5
Nate Dembowski
TheMaestro
Post by TheMaestro »
Im following, but pics upsidedown make it harder... That opening, is it for gas tank?
Sylvan 1978 Seabreeze 1453, '78 Evinrude 9.9, Motorguide R3, Pflueger Trion GX-7
https://www.tinboats.net/forum/viewtopi ... 21&t=25479
dambo0708
Post by dambo0708 »
Yes for gas tank. Like I said I apologize for sum pics being upside down. Idk why?
Nate Dembowski
TheMaestro
Because if you have it open outwards, its harder to load the tank on land. If you are standing beside the boat, and if it opens towrads you, you have to lift the tank over the hatch door.
dambo0708
Post by dambo0708 »
I don't believe I will be taking it out for any reason. Should be able to open the hatch and fill it when needed. Thanks for the input. This is the kind of stuff I'm looking for. Thanks!
Nate Dembowski
dambo0708
Post by dambo0708 »
Did a little more work this evening.
Nate Dembowski
TheMaestro
dambo0708 wrote:I don't believe I will be taking it out for any reason. Should be able to open the hatch and fill it when needed. Thanks for the input. This is the kind of stuff I'm looking for. Thanks!
Then thats ok! Here in Canada you cant fill a portable tank while its in the boat, so Im just used to that :)
One thing you should think about is a vent for the enclosed area for gas fumes. If you search on here, you'll see its strongly recommended you allow for gas vapours to escape from under that enclosed deck. Remember, thats why 'big' boats have a blower!
dambo0708
Post by dambo0708 »
Thank you maestro! I will be sure to do that. Never thought of it
Nate Dembowski
dambo0708
Post by dambo0708 »
Hey guys. Will be finishing u the back of the boat soon and will be moving to the front deck. I find myself knowing exactly what to do for braces after snooping around here. But I have no idea how to measure and cut to fit towards the front? Lol. May be a dumb question but as I said with being a "nube" may it isn't. How can you get an exact measurement to fit at such a great angle?
Nate Dembowski
TheMaestro
Heres how I did it:
- cut the wood to the right length, from bow to wherever it ends; for me it was the front bench.
- cut the wood to the widest part ( again for me its the bench width). You should end up with a rectangular piece.
- draw a line down the centre of the wood, from bow part to end. This should divivde the rectangle into two halves.
- I then carefully measured across the bow every 6", then transfer that to the wood, using the centerline. So if the first measurement is say 9", then measure 6" from the end of the wood, then draw a line crossing the centerline, 4.5" either side of it.
- repeat for the next 6", until you get to the end of the deck.
- connect the ends of the lines, and you have a pretty accurate shape.
I tried using cardboard to trace the shape, but it wasnt as accurate for me. Others have had great success with cardboard, so youmight try that first!
dambo0708
Post by dambo0708 »
Maestro thanks for the help. Its gonna be a good size deck from bow to second bench. I want a nice long platform for the wife. Btw your mod is awesome! Real cool ideas and superior craftsmanship. Good work buddy!
Nate Dembowski
dambo0708
Post by dambo0708 »
Hey guys haven't been on in a while. Been super busy but have been able to do a little more work to the boat. Got a little over 3 weeks till our camping vacation so I gotta get a move on.
Nate Dembowski
riverrat174
Post by riverrat174 »
It looks nice, dude. Let us know how the bow goes and what works for you. I am getting mine ready for a new floor, but I'm further out than you.
"Once you've wrestled, everything else in life is easy." - Dan Gable
My Build
https://www.tinboats.net/forum/viewtopic.php?t=30557
