12 ft Gregor restore project
wlshafor
Sacramento CA
This boat was modded/ build once before. The previous owner let this boat sit outside uncovered for about two years. The outboard was the only thing covered. I will be replacing all the plywood and water sealing. Also the old carpet is coming out and will be done with marine carpet. I also plan on buying new decals for the boat and outboard. Plus powder coating the trailer.
One of the ideas that I would like to have done is a leveled floor or a side console add on but I'm not to sure how to go about this.
Anyways enjoy the pictures. Also how would I find out what year the outboard is?
-Warren
Is there a manufacturers plate on the transom clamp section of the motor? If so, you can look it up or post it here and someone can help you figure it out. If not there, then look for stamped numbers on the block or a freeze plug/welch plug on the motor.
