5052 aluminum sheet for floor and front deck
heron2000
6
Post by heron2000 »
is 5052 .063 thick enough for floor and to build a front deck on my 1436 Alumacraft jon-
typed by ben
Post by typed by ben »
heron2000 » 51 minutes ago wrote:is 5052 .063 thick enough for floor and to build a front deck on my 1436 Alumacraft jon-
youll have to give it plenty of structural support. .063 is mighty thin- aluminum boats are made out of at least .080
give it plenty of support and it will probably work out well for you- but the amount of support that you could do away with by simply bumping up material thickness may make it worth your while.
Lowe 1648M | 25 hp Johnson electric start | Minnkota 40AT
always in progress.
heron2000
6
Post by heron2000 »
you gave me the info I needed - i'll look for thicker plate
thanks
smackdaddy53
Post by smackdaddy53 »
Use 1/8" (.025") with braces on 10-12" centers and you will be fine. Thinner plate ends up costing you more because of all the extra bracing you need to make it solid.
~Mac~
Bigwrench
6
Post by Bigwrench »
smackdaddy53 wrote:Use 1/8" (.025") with braces on 10-12" centers and you will be fine. Thinner plate ends up costing you more because of all the extra bracing you need to make it solid.
I'm researching this as well and had a question isn't .250" 1/4" and 1/8"
.125" ? But 1/8 is the best for floor decking ? So many sizes to choose from it gets confusing fast. .063,.080
smackdaddy53
.25"-1/4"
.125"- 1/8"
I seriously would go with .125", check out my build
~Mac~
bigredxlt
6
Post by bigredxlt »
How about .10" thick? is there that much of a difference between .1 and .125?
Bigwrench
6
Post by Bigwrench »
.25"-1/4"
.125"- 1/8"
OK thank you Ill go see if I can find your Build Thread :)
typed by ben
bigredxlt » Today, 14:08 wrote:How about .10" thick? is there that much of a difference between .1 and .125?
i believe the alumacraft welded and grizzly boats are made from .100. its different from .125 but not that different- but a MILE away from .063.
always in progress.
smackdaddy53
If you have seen my build you will notice I tend to over engineer!
~Mac~
