Alumacraft 1236 Project
Maxamillion
6
Post by Maxamillion »
finally got all my wiring done!
Maxamillion
6
Got my front platform done! Marine ply, waterproofed with spar urethane. Installed a clear, light base, and a homemade trolling motor mount!
CMOS
5
Post by CMOS »
Nicely done!
Out of curiosity - are you soldering your wire connections or just crimping? If possible, I would strongly suggest you solder them, then cover connection with Heat Shrink tubing.
CMOS
1982 Johnson 15 HP - in pieces, in progress
Currently boatless :(
Maxamillion
6
Yep all of my wires are soldered and have shrink tube around them!
Maxamillion
6
Added fold down cup holders. I used double side outdoor mounting tape. They work really well and fold out of the way.
Tape I used
Tape I used
Maxamillion
6
This is a great idea for anyone with a Jon boat. It's an Atwood cockpit caddy, I used the same double sided tape and stuck it to my transom corner Braces, it covers up the corner and gives you a great place to store tools.
Maxamillion
6
Added a Smiths tournament rod rack. I screwed 1" strips of wood to the back, then applied 20 pound double sided sticky tape and applied it to the sidewall of the boat. It works awesome, rock solid.
Maxamillion
6
I have a question for you guys, found an older minkota turbo pro 42 pound thrust trolling motor on eBay, it is a power drive model. Has anyone had experience with these motors or older power drives in general? Thanks
HeavyHook
5
Post by HeavyHook »
I noticed not many replies so I created an account to let you know that you're doing a great job. I recently purchased a 14ft Alumacraft MV model.
The owner before already added in many great accessories including the flooring etc... I am now on the forums trying to figure out other ideas that I could use.
What carpet is that in the back of the boat you are using? I was contemplating coating that area because of the scratches that occur in that area.
I also like your trolling motor mount. I am in the process of making a decision about creating / fabricating a mounting bracket for a bow mounted trolling motor. Right now there is a transom mounted Minn Kota 50lb that is too hard to navigate with in the back. It is being moved up weather it be with a mount similar to what you went with or I get a bow mounted style.
Maxamillion
6
Thanks for the reply! Was wondering if anyone was following. The material in the back is a all rubber carpet sort of mat. Works great for preventing scratches!!
dwwscran
Post by dwwscran »
boat is looking great. what did you end up using for your starter wires? i remember my first boat... 1432 polarcraft... after 3 years it was way to crowded with just me in it lol.
Maxamillion
6
I'm using 12 gauge wire extension! Works great so far
Maxamillion
6
Picked up a new toy today. Minkota turbo pro 42 pound thrust trolling motor. It's a powers drive model. Almost perfect condition. Bolted it through my existing platform with stainless hardware. I wanted a power drive over a cable drive because the footpedal like is smaller, the entire package takes up less space, and I have enough foot pedal cable to run the pedal on top of a bench seat where I fish a lot.
Maxamillion
6
Getting my front floor carpeted!
canadian omc
Post by canadian omc »
=D> Looks good.
