"Old Gold" - 1958 Alumacraft Deep C
g0nef1sshn
5
Post by g0nef1sshn »
really looking good!
mgros483
6
Post by mgros483 »
Just a boring update, I rebuilt the carburetor and the water pump last night so it's fresh and clean for the weekend.
Just for anyone contemplating changing a water pump, it's super easy. I have never done it before, and in fact have never even pulled the lower unit off of an outboard. I followed the factory service manual process, but honestly other than disconnecting the shift rod, I probably would have just figured it out on the first try without the manual. So, if you have a new water pump kit sitting in your garage and have been procrastinating it because it sounds difficult (exactly what I was doing up until last night), just do it. It took me 30 minutes, I did it out in my yard, and it was dark by the time I finished and I still got it right.
Rebuilding the carb was uneventful. I've done a lot of carb fixing in the past so I knew I had a shoddy float valve. I replaced it as well as pulled apart everything that wasn't under an orifice plug. The only thing that is still bugging me is that my low speed needle is pretty worn. It doesn't have the greatest idle in the world, but it works. I was going to order a new one, but they're $50 each, which I think is crazy. I'll just stick with the worn one until it gets bad enough that I think it's worth dropping a big-face Grant on.
Planning on taking it out this weekend then if the weather cooperates, It'll be on to painting next week.
https://www.youtube.com/embed/h62q6ArrINc
Marty
1958 Alumacraft Deep C - 15'
1976 Evinrude 40 hp long shaft - Model 40655A
Build thread here:
https://www.tinboats.net/forum/viewtopi ... 21&t=34712
TexasLoneStar56
6
Post by TexasLoneStar56 »
I have been following your thread and watching from afar. You have come a long way. Keep up the good work! =D> =D> =D> She's looking purdy! :mrgreen:
I'm with you on the part of playing for awhile and let the work start back up in the fall/winter. It's summer time.....go play! :LOL2:
M
Tyler, Texas
PS: I love the old windshield. You are very fortunate to have it.
Treating others as we want to be treated makes for a happy life!
1956 Lone Star Clipper 16' powered by 1960 Mercury 400E "Miss Fifty-Six"
14' Ouachita Flat Bottom powered by 1971 Johnson 9.5 "Desert Storm"
mgros483
6
Post by mgros483 »
Proof that photoshop can make anything look good...
Should get around to the painting soon, but until then, proper positioning and photoshop are key to a good pic :)
ImageGOPR1416 by Photo 144, on Flickr
Marty
Build thread here:
TexasLoneStar56
6
=D> =D> =D> Beautiful!
Johnny
6
Post by Johnny »
just to amplify the others, I also am in AWE of your craftsmanship !!
Of all the positives, only one negative gnaws at my innards . . .
and that is the two steel gas tanks.... They appear to be permanently installed.
Here in Florida, boating is as popular as the Disney attractions.
we see a LOT of gas station fires where people fill their metal gas containers
while inside the truck bed, landscape trailer or boat. If you fill your cans while in the boat,
my personal and very strong advice is to make a grounding wire with an alligator clip on each end
and ground the tank to the appropriate ground somewhere outside your vehicle/trailer/boat.
Please use your best judgement and ample caution when refueling.
Jus my Dos Centavos
https://www.tinboats.net/how-to-build-a-transom/
https://www.tinboats.net/varnish-vs-polyurethane/
All about Primers = https://www.tinboats.net/primer-and-paint-basics/
Paint, Thinners and Applications = https://www.paintingforpainters.com/
1959 Lone Star Malibu 14'
mgros483
6
Post by mgros483 »
Barefoot,
Thanks for the tip. I had heard of the phenomenon, but I didn't know if it was a legitimate concern or not. More often than not, I fill my boat with a 5 gal. plastic can, but occasionally I do fill from the pump. Does the potential for this type of fire to happen when filling with a gas can? I think not, but I don't know the underlying cause of the ignition.
Thanks for the kind words on the boat, it's a fun project. Can't wait to get it painted up, then it'll look good finally.
Marty
Build thread here:
Johnny
6
Post by Johnny »
again - you have done an AWESOME job on your build !!!
Here in Florida, there are stickers on ALL gas pumps containing safety advisories . . .
NO cell phones, NO smoking, NO filling of containers that are not on the ground,
NO going inside your car and coming back out when the filler hose shuts off.
I have seen similar stickers in the past while traveling. So, all these notices are in place for a reason.
Gasoline vapors are heavier than air when cold, lighter than air when warm. Like in summer.
So theoretically, gasoline vapors are all around you when fueling your car or containers.
One spark is all it takes. And, just about anything can cause that ONE that ruins your day.
Google up Gas Station Fires and see what you find. It's not pretty.
https://www.youtube.com/watch?v=tuZxFL9cGkI
https://www.google.com/search?q=gas+sta ... 97&bih=604
My bass boat has a plastic 12 gallon tank that is too heavy for me to move around when full.
So, I use the plastic 5 gal jugs and set the jug on the motor and siphon the gas into the
12 gal tank. I never ever fill jugs while in the back of my car. Never.
Err on the side of safety, and you will live to fish another day.
and, if you think it can never happen to you - - -
check out the recent post of BowHunter1661 - - - and ask him how he feels about the saying,
it only happens to OTHER people - never happen to me.
Oh, one technique that I practice, and try to pass on to others, is - - -
do not stand between the gas hose and your open car door.
so if there IS a fire ball, you are not trapped between the two. Think about it.
stand on the outside of the hose - just in case you have to run away quickly.
Just put some thought into how to protect you and your beautiful investment.
mgros483
6
Post by mgros483 »
Thanks Barefoot, but maybe I worded my question wrong. Do I still need to worry if I'm filling my boat tank by using a plastic jug? I think not, but who knows. I always fill my plastic gas jug on the ground, but I guess it's just coincidence rather than attention to safety. I just think it's easier than reaching up in the truck bed the whole time.
As for the warning stickers, yes, we have them here too. In all honesty I've read them and still do all those things except smoke.... Sometimes you get overwhelmed by all the warnings on every single thing you look at in this litigious world we live in. Never know which ones to heed and which to ignore.
Thanks for the advice, you may have saved my boat and maybe me from disaster.
PS Bowhunter's story scared me straight yesterday, I think everyone should read that post. In case you haven't seen it: https://www.tinboats.net/forum/viewtopi ... =3&t=38624
Marty
Build thread here:
Johnny
6
Post by Johnny »
in my line of thought, there shouldn't be any chance of "static spark" when using
the plastic jugs and plastic hoses to transfer fuel from one tank to another.
IMO, it is your BODY that creates the spark. And looking at several boats on this
forum, the battery is almost always right next to the fuel tank. Including mine.
If you somehow create a spark from the battery to your body - poof = day ruined.
I have a fully open and well ventilated compartment where my gas and battery are kept.
When transferring fuel, ALL the hatches are open.
Am I paranoid about gas ?
LOL you betcha !! LOL I wish I had a photo of myself at the age of 10 when I poured gas
all over the grass to burn it off to play baseball. I guess I was thinking (or NOT thinking)
it would burn slow like kerosene . . . WHOOOSH !!! all my hair, eyebrows, eyelashes - gone.
some blisters on my arms and legs. I had on shorts - no shirt or shoes, which probably
saved my life or severe injuries from the burning clothes if I had had on long pants and shirt.
I guess the older we get - the more awful things we see - and the more cautious we become.
Jus my Dos Centavos
TexasLoneStar56
6
AMEN! We didn't get old by being a fool. Just sayin......
Fact: a cigarette will go out if dropped in liquid gasoline.....it's the vapors that ignite.
Very, very good advise on here. Thanks for sharing.
I have often wondered about the battery being so close to the gas containers. I see that in a lot of flat bottoms here, including our daughters'. Plastic cans and open compartments, but never the less.....all it takes is one spark.
Keep up the good work on "Old Gold"! She's a beauty! :D
mgros483
6
Post by mgros483 »
Fun day out with the dogs. It's really hard to get this thing painted when it's on the water every weekend!
Marty
Build thread here:
TexasLoneStar56
6
Totally awesome pics! =D>
No worries.....summer is for having fun on the lake; winter is for painting. :D
VinTin
5
Post by VinTin »
I have a 15 gallon fixed in place plastic tank in one of my aluminum boats. A precaution I take before filling is to touch the gasoline pump nozzle to the side of the boat before flowing any fuel. This should discharge any static electricity. On the subject of painting......I've not seen a paint yet that I like more than the beautiful patina bare aluminum develops. Ever seen a painted Airstream camping trailer? Didn't think so.
mgros483
6
Post by mgros483 »
@vintin I'd love to have bare aluminum, that's my favorite too! But, there are about a thousand holes in this boat above the water line from the previous owner, so it would look horrible if polished
Marty
Build thread here:
