Front Deck Build
nicdicarlo wrote:I use AutoCAD a lot on my computer at work. I'm not a trained drafter, but I have a pretty good knowledge of the program and can create pretty nice figures. I made a nice layout of my crawdad in preparation for building the new flooring. PM me if you want me to whip something up for you...I'm always looking for stuff to do at work thats not actually work related. :twisted:
Save the plan for the crawdad, I might need it If I can score a cheap crawdad over the winter.
Please use our Amazon Affiliate link. It costs you nothing and sends a few cents to the site.
nicdicarlo
Post by nicdicarlo »
Jim, will do. I currently have a drawing with the dimensions of the boat, the internal framwork, and the usable floor space. Once I decide how excactly I want to cut the floor I will make an "AS BUILT" figure. I will keep you posted.
Please don't dominate the rap, jack, if you've got nothing new to say.
Post by Waterwings »
pbw,
Glad to help! :) .
I don't know a thing about autocad; I made the rough sketches of the gussets on MSPaint, so I'm glad they weren't to bad and conveyed the idea I had :)
pbw
Post by pbw »
Updated gussets are done, need more mounting hardware I'll get it tomorrow. Then I'll connect the gusset with 2x2 and be done framing! After that I'll install new wiring and cut decking while waiting for Flotation foam and other parts.
The picture make them look unlevel but i've about wore my level out ensuring they arent!
PBW
Looks plenty sturdy to me, and I'm glad my idea worked out for you :)
pbw
Post by pbw »
Waterwings wrote:Looks plenty sturdy to me, and I'm glad my idea worked out for you :)
Yea I own you one.
PBW
Yea I own you one.
Nope, you let me in on the design phase so to speak. Consider it even :)
bassboy1
Post by bassboy1 »
I like the idea of the gussets. But, as some of yall have figured out from my posts, I can't leave good enough alone. :)
So here is my 2 dollars worth (inflation)
You may want a bit of support on your four corners. I circled all four, but only the rearward 2 corners may need it.
pbw
Post by pbw »
bassboy1 wrote:I like the idea of the gussets. But, as some of yall have figured out from my posts, I can't leave good enough alone. :)
Where is the circled photo?
PBW
LOL! bassboy1 always does that! :D
bassboy1
Post by bassboy1 »
Did I forget the picture AGAIN????
Yes, as Jim said, I do it all the time.
Here it is.
pbw
Post by pbw »
bassboy1 wrote:Did I forget the picture AGAIN????
Here it is.
That is my plan! :D
PBW
pbw
Post by pbw »
NO updates today I'm staying inside and resting before this dang cold takes me over!
PBW
pbw
Back on track!
Post by pbw »
I can't hear very well dang cold!
I finished all my framing. I've put on my test small sheet of plywood 5/8 and jumped up and down! Its solid.
Then I starting putting on several coats of water proofing.
Third coat drying
Now I need my plywood, going to borrow a truck soon to purchase it.
My flotation foam hopefully is in UPS hands.
PBW
It's gonna be great! :)
