What do you use to clean your hull
ricerocket71
Post by ricerocket71 »
My New tracker has been in the water all summer and needs to be cleaned, any suggestions?
Howard
Post by Howard »
Since your boat is new, I would contact the manufacture and follow their suggestion. This will keep you with in the warranty guidelines. They have the best and most experience with their own materials. Generally, most manufacture will do allot of trial runs on different products to see what works the best.
Nevillizer
Post by Nevillizer »
Dawn Soap, a good stiff brush, and some high pressure water. Works every time. If you have a lot of algae or "river / lake muck" you might use a large scotch-brite pad when you scrub it.
Well behaved people rarely make history!
redbug
Post by redbug »
simple green!!!!
emoticon-tv-002
WE'RE ON A MISSION FOR GOD
JL8Jeff
6
Post by JL8Jeff »
I know this is an older thread but I just pulled my Lowe from sitting in the river all summer and decided to try the Simple Green on a small patch last night. Using a stiff brush, it cleaned up much better than I expected. I did hit the algae with some bleach at the boat ramp when I pulled it out, that helps kill it off. In the past, I have used CLR or Lime Away on my fiberglass boats and they cleaned up nicely after several rounds of wiping it down. The Simple Green will take more elbow grease, but it seems to work pretty well and isn't as harsh on the environment.
2001 Lowe Roughneck 1652 VT with Merc 60/45 jet 2 stroke
Clifford_Akov
6
Post by Clifford_Akov »
Careful with the bleach, it can do a number on aluminum if you don't wash it right off. Best not to use.
"Yola Mia", 1994 Alumacraft V-14, 25 Honda 4-stroke outboard
Edintampa
6
Post by Edintampa »
IF you have a Big Lots store near by they have some stuff called "Awsome" that works great and very cheap too!
JL8Jeff
6
Post by JL8Jeff »
Oh well, so much for the Simple Green. I got around to the side that was exposed to the sun and it's putting up a good fight. I still have some lingering tendonitis in my elbow from shoveling too much snow last winter so I need to take it easy with the scrubbing. It's not a large area, but it's taking more effort than I had hoped. With the fiberglass boats I've had in the past, the CLR or Lime Away worked fine but I don't want to risk it on the aluminum.
turbotodd
Post by turbotodd »
See if you can find a product called "Zing" boat and pontoon cleaner. By far the best aluminum cleaner I've ever used. I use it for cleaning radiators at work, never used it on a boat but all the boats we sold are painted and the aluminum cleaner wouldn't do anything. It works it's best on bare aluminum.
SumDumGuy
6
Post by SumDumGuy »
ricerocket71 wrote:My New tracker has been in the water all summer and needs to be cleaned, any suggestions?
Put it back in the water and forget about cleaning. :evil: :LOL2:
barnrundrifter
5
Post by barnrundrifter »
iv got a dumb question, so i have a 77 15ft fisher marine "fisher" mostly still factory ..... so its just got a blue " im guessing vinal sticker" pin stripe along the water line .. my question is .... did or do boat companys put a clear coat on the boats or is it ok to try to polish and maybie wax ? or do i run a risk of burning through some sort of protective coat
I never make the same mistake twice , becouse im to busy making new ones!
