Need anti-slip material
Restrained
In the process of restoring a 20 year old aluminum Tracker. There was a piece of black anti-slip material installed on the bow that had adhesive on one side securing it. Can someone point me in a direction to get material to replace without needing to buy a 15foot piece? Thanks in advance
If the anti-slip material is rough like roof singles, and is used for outdoor steps, check out HD or Lowes. I've seen it in strips and short rolls.
The stuff I have seen for skateboards is similar to sandpaper. Mine is a bit more forgiving to bare feet.
[url=https://www.tinboats.net/forum/viewtopic.php?p=337382#p337382 said:
Restrained » 29 Dec 2013, 15:37[/url]"]The stuff I have seen for skateboards is similar to sandpaper. Mine is a bit more forgiving to bare feet.
You're right about the skateboard tape, I thought thats what you were describing. Hope you find the correct stuff.
I was thinking of using this stuff for my floor I just added to my alumacraft 1436 ..........
https://www.amazon.com/dp/B0006HVKM4/ref=wl_it_dp_o_pC_nS_ttl?_encoding=UTF8&colid=HEDX1YWD5VED&coliid=I33XPP2GHUE83B
It sounds much like the stuff they put in showers for old people. I'd call your local HD or Lowes and say that's what you're looking for. Also I know bass pro sells something in strips like you described.
Have a look at this stuff. Use the zoom and it looks like it's just a coarse texture instead of grit like sandpaper.
https://www.amazon.com/Shoreline-Marine-Skid-Tape-White/dp/B00BNTZIFO
