New Member Old 1959 Lone Star
monriverguy
5
Post by monriverguy »
Hello to everyone out there and thanks for all advise in advance.
I just got my second Lone Star boat a 18 ft 1959 Eldorado, and it needs lots of TLC and then some. The transom was tore out by PO. Silicone smeared all over the in side at the seams and the stringer's. And the paint on the bottom is nearly down to bare. I will post pic's on here tonight if i can. My question is where do you all think i should start to see if this old gal can be saved? i have tore out the flooring and the sides and have filled her up part way with water so far just 3-4 leaks around rivets. How far can i fill her up safely?
And once again thanks to all( i really love the way this tinner looks)
John
Kismet
Post by Kismet »
I really love the way this tinner looks
You answered your own question. With love in the equation, rational thinking goes by the way-side.
Be safe, have fun, don't keep receipts.
=D>
Kis
Enjoy every sandwich
1955 Alumacraft Model A
https://www.tinboats.net/forum/viewtopic ... 08&start=0
1959 Alumacraft Model F
https://www.tinboats.net/forum/viewtopic.php?f=3&t=25386
1980 Alumacraft Model F7, 1955-56? Johnson 10hp
https://forum.tinboats.net/viewtopic.php?f=4&t=35326
1956 Alumacraft Model RB
https://www.tinboats.net/forum/viewtopic.php?f=3&t=39249
lckstckn2smknbrls
Post by lckstckn2smknbrls »
Fill with water up to the waterline.
TexasLoneStar56
5
Post by TexasLoneStar56 »
=D>
What Kismet said! :)
We,too, have an old LS. A '56. I've been working on her since July. All you need is the want to, a few kind words and a little patience. She'll be worth it when you see her on the water for the first time! 8) Post pics!
Keith
Texas
Treating others as we want to be treated makes for a happy life!
1956 Lone Star Clipper 16' powered by 1960 Mercury 400E "Miss Fifty-Six"
14' Ouachita Flat Bottom powered by 1971 Johnson 9.5 "Desert Storm"
jigngrub
Post by jigngrub »
When filling a boat with water for a leak test, watch your trailer tires to judge the weight load.
The easiest long lasting way to fix leaky rivets is like this:
Rum, wenches, and song... just another day on my boat.
monriverguy
5
OK a few more questions, Where can you get rivets like that, Where can you get the rivet gun at ? and what kinda of epoxy was that i thought everyone used 3m 5200 to seal the rivets.
jigngrub
Post by jigngrub »
You can buy the rivets here:
https://www.rivetsonline.com/rivets-en/b ... ivets.html
You can buy the setting tool there too, or you can get one from Harbor Freight for $20.
You can get Loc-tite marine epoxy from Home Depot or Wal-Mart... or you can use 5200, but 5200 is thinner and runnier/messier.
monriverguy
5
OK thanks all for the advice and encouragement so far, so here is the question , The PO put silicone on all the rivets and seams on the inside of the boat, I have the floor removed and plan on putting in the new transom, so far i have only found 3-4 leaks mainly in the rear of the boat? do i just leave the silicone on? do i try to still wire brush it off and replace with glove it? And it looks like it is stuck on there very well..
Thanks again to all.......
TexasLoneStar56
5
Don't use a steel wire brush. It will leave it's bristles behind, causing rust later. Instead, use a brass brush. I used a brass brush on a drill. Worked pretty good. Then, I drilled out the rivets and went back with new rivets. No leaks.
Keith
lckstckn2smknbrls
TexasLoneStar56 wrote:Don't use a steel wire brush. It will leave it's bristles behind, causing rust later. Instead, use a brass brush. I used a brass brush on a drill. Worked pretty good. Then, I drilled out the rivets and went back with new rivets. No leaks.
Keith
Stainless steel and nylox wheels are safe on aluminum.
TexasLoneStar56
5
Keith
I did not know, or realize that. Thanks! :wink:
monriverguy
5
Thanks for all the great tips got a brass wire brush tried it out i got many hours of grinding ahead of me.........
monriverguy
5
sorry all wrong pictures new to this site i will try again
monriverguy
5
ok here is what i am facing any help much appreciated......
monriverguy
5
OK all been busy here but got the transom cut ,glued, and coated with spar.. took it home and it fits real nice.. MY first transom..... :D
