Bench Seat Removal - If I may opine, what one needs to be aware of is the longitudinal rigidity that is lost by seat removal, whether it is 1 or all. I personally believe you need to replace it with some sort of 'structural integrity' tying the stern to the bow, maybe even cross-thwart too. See below, a gross example - yes, but one just to illustrate the point. If there were NO seats or longitudinal axis support, when you hit a wave hard ... that hull could fold up like a piece of tin foil.
If I were doing it, on either side of where the seat used to be, I'd add a heavy wall (1/8") aluminum L-channel (or thicker strip) along the gunnel for a good 2-3 feet both fore & aft, if not longer. This could be incorporated as part of rod lockers or other decking frame.
Only in RARE instances, like only on small ponds or lakes without a big HP motor on the back, would I ever envision stepping aboard such a small tin that otherwise didn't have such longitudinal support added back in.
