I just picked up a 1999 SeaArk 1652, it's all welded and built like tank. The only problem is like most old boats it's full of cut outs and screw holes. Rather than getting everything patched on the console I figured id neatly cut out large areas and replace it with panels made with whatever, carbon fiber sheet? ABS plastic? Same for the electronics areas which I've seen someone use a cutting board as a mounting plate. Just looking for examples and suggestions.
