Douglasdzaster
- Joined
- Sep 19, 2020
- Messages
- 780
- Reaction score
- 457
- Location
- Smithville,Texas
- LOCATION
- Smithville, Texas
Hello everyone,
I need some of your wisdom and advice with my first aluminum boat.
I have a 1982 Monark 16/52. I brought the motor back to life and have really been enjoying the boat. I noticed a little water the other day and decided to remove the floor ( that the boat came with) and check it out. The floor has good plywood on the boat then it’s topped with tin or aluminum (old signs) and that’s covered with a none slip material that’s holding up well. Had to laugh when I seen the signs though.
Found a small leak on one of the boats dinged spots no big deal.
I’m more concerned about when I removed the floor some of the cross members underneath are pitting. What can I do to repair and stop it from getting worse?
Also when I put the floor back what screws should I use. Several of the old ones broke off when removed. They are all corroded. I want to replace them with something that won’t react badly with the aluminum. Or can I coat some stainless screws with something?
Y’all’s help is greatly appreciated. I want to get back on the water.
