New 2017 25hp 4 stroke efi yamaha
Have a question about your motor? All motor talk and questions go here.
turbotodd
Post by turbotodd »
A 250cc dirt bike is in fact near 40hp nowadays. But keep in mind that they also require rebuilds at around 10 hours use. Or at least that's the recommended interval. They make power but at around 12,000 RPM. An outboard motor running 12k RPM at full load for hours on end will not last. Not at all.
The 25hp 2 stroke yamaha.....which one are you talking about? twin carb? Single carb? 3 cylinder?
I get to work on motors, specifically Yamaha. And I can tell you first hand experience that out of the thousands that are in this area, the ones I see most often, are 2 stroke motors. Now that could be due to more of them being out there or it could mean that they're broken more. I don't know. That's just what I see.
When the local duck hunting areas were 25hp maximum, I saw TONS of 3 cylinder yamaha's out there. Mostly because they'd pull a bigger prop and run a couple mph faster (stock) and then the modified ones would make a LOT more power and go faster. Those duck hunters were mostly boat racers. But there were a few 4 stroke 25's out there too, and of those guys and gals, they all said the same things. They never had to work on 'em unless they were doing something really stupid like beaching their rig at full speed or purposely jumping logs or whatever.
Local river is lined with boat docks, a bunch of them have professional guide services. At those guide docks, you see one Merc and the rest are Yamaha's, mostly 4 stroke 40hp jets (40/30). On the river, you rarely see anything but Yamaha outboards. On the lake yesterday for the eclipse, I saw one mercury on a bass boat, and a few I/O powered runabouts, and most everything else was Yamaha. Not a single Honda or junkzuki to be seen anywhere. But there's only 2 'zuke dealers in the state, both of which are 100+ miles away from the 2 main areas that I am fishing. In my mind, if these things were so great, why are they not all over the place?? We go down to the Gulf every year and there are bigger rigs everywhere. Rarely do I see anything but 250hp+ Yamaha's. This last spring I spotted a rig with THREE 400hp Mercury's but I assume it was only because Merc is the only 400hp outboard out there. Or does BRP have one now too? We don't see that stuff around here, too far inland, and no boats big enough to require that much motor.
Stumpalump
6
Post by Stumpalump »
turbotodd wrote:A 250cc dirt bike is in fact near 40hp nowadays. But keep in mind that they also require rebuilds at around 10 hours use. Or at least that's the recommended interval. They make power but at around 12,000 RPM. An outboard motor running 12k RPM at full load for hours on end will not last. Not at all.
They de tune those race bike motors a smidge for quads and they last forever. Ring it's neck out for 15 motos on the rev limiter and 10 hours sounds right. The Hondas ect have the same 10 hour spec. Feeding a 25hp version ice cold water should last 1000's of hours. That motor will be bitchin!
1991 18' Valco Bayrunner Evenrude 48 SPL
Arizona
scoobeb
Post by scoobeb »
Everyone has their own opinions of what's the best,etc.. I'm not one to pick one brand over another. I just like the 25hp 4 stroke suzuki, especially for the price. If you want to know my favorite engines in the 25hp range it's hands down the early 90s 25hp 2 stroke merc, then the double carb 25hp 2 stroke yamaha. I like how light they are and powerful. Now in the 4 stroke department I love the 25hp 4 stroke suzuki because I've had one and it ran awesome. I love tohatsu to,they make a crap load of outboards for them of course, merc and used to be nissan up to 30hp,evinrude 4 strokes up to 15hp. I don't have any particular brand I like better than others it all comes down to features imo. If I go 25hp 4 stroke, it will be the suzuki, if I have the money I will go 25hp etec DFI for a 2 stroke.
Everyone again has their own favorite engine and brand.
scoobeb
Post by scoobeb »
I live on the Gulf as well and I agree 90% of the outboards on the water is dominated by Yamaha and Mercury hands down. Then comes every other brand mixed. So if that is the case that would explain more yamahas and mercs being in the shop more than any other brand.
You may laugh but the best engine I've ever owned was a 2001 9.9hp 2 stroke tohatsu. Back in 2001 I knew nothing about engines,I was just learning about engines and all I knew was 50:1 gas and go. I ran that thing well over 1000 hrs in say 7yrs,never did a thing to it,not because I didn't want to I just wasn't maintenance smart. All I did was flush the saltwater out and clean the engine after every use and lube the whole engine with walmart super tech lube. No impeller change,no spark plug change,no lower unit oil change and that engine ran flawlessly for 7yrs I had it and my buddy still has it I sold it to and runs as good as the day I bought it. What great engines tohatsu builds.
DaisyCutter
3
Post by DaisyCutter »
I ordered this boat on December 23rd. Now, finally... the motor is mounted.
https://youtu.be/w-b4nPzhHYA
Lake test this weekend.
Stumpalump
6
Wow! What a cool motor and you did a great job highlighting it's features. Can't you interface those small Yamahas with electronic fish finders and plotters to tell you the vitals? Are you going to tell us what prop, RPM and speed you are seeing? Now is the time to get Cabellas to give you the perfect pitch prop anyway. Congradulation!
Arizona
DaisyCutter
3
There is a really cool wireless digital gauge called 'Command Link'. I may look into it it the price isn't absurd.
I did check the prop.
Stumpalump
6
Not sure you would want the speed and fuel consumption part of this but the tach portion alone is about half.
https://www.simyamaha.com/Command_Link_S ... -91-00.htm
It should run between 23 and 27 with that prop.
Arizona
pbw
Post by pbw »
My boat has similar specs as yours and with my 4 stoke Yamaha 15hp and two adults I run 21 mph. Would love to see what that 25 could do on my tin.
PBW
Zum
Post by Zum »
Well that didn't take long....just kidding
I'm sure you will be happy, enjoy your fun.
hounddog
2
Post by hounddog »
Very nice rig there! I bet it'll be worth the wait!
DaisyCutter
3
It was a busy holiday weekend at the lake, but I did get a chance to try out the Yamaha 25. We managed 27 mph on the GPS. I was hoping for more, but that was in chop, with 2 adults, and a bimini top. There was a fair amount of porpoising, so I will have to adjust the load a bit.
Overall I'm really happy.
jasper60103
Post by jasper60103 »
Good to hear. Thanks for the update.
Sent from my SM-G386T using Tapatalk
2018 Tracker Grizzly 1648
scoobeb
Post by scoobeb »
DaisyCutter wrote:It was a busy holiday weekend at the lake, but I did get a chance to try out the Yamaha 25. We managed 27 mph on the GPS. I was hoping for more, but that was in chop, with 2 adults, and a bimini top. There was a fair amount of porpoising, so I will have to adjust the load a bit.
That is a decent overall wot speed. Just food for thought, I understand this contradicts the manual but break that motor in hard while varying rpms if you want to seat the rings properly. You get one shot at it. If you baby it your motor will never run at full potential as far as power wise due to the rings not being seated correctly and it sounds like you want as much wot speed as you can get . Most important thing is always warm it up for a few minutes and your good to go. Good luck.
haute
6
Post by haute »
Fwiw I have a 2016 Alumcraft V16-15 (b/c my old 15hp motor was a short shaft), and picked up a 2009 Yamaha 25 2-stroke (dual carbs).
With me, my wife, two young kids, and one or two of my kids' friends, gear, battery, and around 55lbs in fuel (1 x 6gal tank, 1 x 3 gal spare tank) I can hit almost 27mph on calm water with no head wind.
With a fully loaded boat, me, wife, two other adults, our two kids, food, gear, battery, gas, I can hit 23 mph, although it takes longer to plane out.
Both of those speeds are WOT.
At 1/2 throttle, I get 24(ish) and 21(ish) respectively, depending on waves and wind. I rarely run at WOT, as the extra gas just isnt worth the extra 2-3 mph. I use just under 3gal to run 25mi at that throttle position/speeds.
I have been considering ditching my cherry Yammie for either the Suzuki DF25A or the new Yammie F25, as I am getting sick of doing the 2 stroke oil dance, the noise, and the gas pigging, so I'm **really** interested to hear how the new one performs with your V16...
I was leaning toward the Suzuki and its three cylinder setup. I would imagine the torque band would develop at a lower range, but that's just supposition, but I love my Yamaha, and if I replace it, I'd probably drop the extra coin on the new gen F25...
2016 Alumacraft V16, previously 2006 Lowe LV1457 Sea Nymph
2009 Yamaha 25hp (dual carb 2-stroke)
1990 Evinrude 15hp (from previous, now backup motor)
Minn Kota Endura C2 50lb thrust
"Good judgment comes from experience, and experience comes from bad judgment."
- Barry LePatner
