How to Mount Kicker Motor
mcganiel4N
1
Post by mcganiel4N »
Hi All,
I am new to this boat thing and scored a a long shaft tiller9.9 kicker but my transom is much higher than where I need to mount it.
I have a 172 fazers smokercraft 1994. My 90 johnson sits low on the transom.
What would be the best way to mount my kicker?
this is the stern
Weldorthemagnificent
3
Post by Weldorthemagnificent »
[ external image ]
This is slick.
earl60446
Post by earl60446 »
Brackets are made to bolt to the transom to support a kicker motor. Couple examples below.
Tim
https://www.anchoring.com//products/sta ... woQAvD_BwE
https://www.cabelas.com/product/Panther ... lsrc=aw.ds
16ft 1989 Fisher SV-2 w 1988 48hp SPL Johnson "CIGAR BARGE"
(engine looks like a wreck but runs great)
Used to have 1972 14ft Lund w 1977 15hp Mariner
(engine looked great but always ran marginal)
XLINE SPORTSMANS CLUB
eshaw
3
Post by eshaw »
The nice thing about the one Weldorthemagnificent posted is it keeps the kicker centered.
jethro
6
Post by jethro »
mcganiel4N wrote:Hi All,
this is the stern
You may have enough freeboard to install a motor directly to the transom such as I did on my boat. The tricky part is always if it's high enough to get the motor completely out of the water while the boat is on plane running the main. It's good you got a longshaft so your motor is not sucking air in heavy, following seas. That is the reason most people need to use an actuating bracket. I do not have to use a bracket with my 6hp longshaft because the transom is so dipped for the main, which yours looks to be as well.
Mine is only mounted to starboard of the main because of my swim platform. You will be better off rigging up remote steering with it on the port side of the main as it seems you are planning by the picture.
I fish, therefore, I am.
1993 Starcraft SF 14 DLX side console with 25 hp Mercury 2 stroke
2003 Sylvan 2100 Profish walkthrough with 150 Mercury Saltwater and 6hp Mecury 4 stroke kicker
mcganiel4N
1
Thank you everyone for your replies.
My motor is 86 lbs per the pdf I found for it. I can carry it pretty easy so it must be that weight. :D
Any way I am going to be trailering this thing to all the reservoirs by me and don't want to have to take the motor off. Also i am not the richest person. I was looking at ebay and want something like below. I will have to make a bigger backing plate for th motor mount plate, also would like to make a backing plate for inside the transom but I want to make sure that I can tow with it on permanently. Will these things hold up to towing is my biggest concern? if not what brand will. Thanks for the help.
https://www.ebay.com/itm/Aluminium-Outb ... 0005.m1851
jethro
6
Post by jethro »
When I was researching a kicker for my last boat I would have had to use a plate and what I found was none of the actuating plates are suggested for trailering with the motor installed. That said, I have seen people doing it on kicker plates with the use of ratchet straps and whatnot.
mcganiel4N
1
jethro wrote:When I was researching a kicker for my last boat I would have had to use a plate and what I found was none of the actuating plates are suggested for trailering with the motor installed. That said, I have seen people doing it on kicker plates with the use of ratchet straps and whatnot.
yep that is what i am going to have to do. thanks!!!
CedarRiverScooter
5
Post by CedarRiverScooter »
4N - That is the bkt I installed. I added an extra link on each side to stiffen it up.(used alum angle).
I have a 4hp that I leave on ig while trailering, have it tied up solid so it doesn't bounce.
I would be leery of it unless it is reinforced.
