RaisedByWolves said:Sucking air is not going to be as noticeable at full throttle as there is no vacuum or at least not as much as at part throttle.
Pappy said:RaisedByWolves said:Sucking air is not going to be as noticeable at full throttle as there is no vacuum or at least not as much as at part throttle.
As fuel flow increases so does the vacuum required to get it to the engine.
To let you off "the hook" I am assuming you are talking about vacuum on the induction system not the fuel system.
Hint - just say yes.
