- Joined
- May 15, 2010
- Messages
- 3,665
- Reaction score
- 323
- Location
- Central Florida
- LOCATION
- Lake County, Central Florida
Had a boat "come back" after doing the complete boat fuel system and carburetors. Engine is a late 90s Johnson 175 in the 60-degree configuration.
Anyway...ran fine when it left.
Customer came back in with a less than stellar mood claiming that the engine ran perfectly for almost exactly 4 minutes then fell on it's face and would not accelerate on plane. "You guys ruined my weekend"
Now....keep the 4 minute time span handy in your brain.
4 minutes is probably about the amount of time it takes for the engine to run out the fuel in the fuel lines from the tank, through a large water separating fuel filter, into the engine fuel pump and fill the vapor separator tank and carburetors.
After this amount of time the engine is on whatever the customer filled his tank with or if the tank had water, etc.......
Took a fuel sample. Something was strange about the gasoline in the sample. Did not smell right and did not "feel" like gasoline. Was not rotten gasoline.
Took the gasoline and did an Ethanol test on it. Results are below !!
pic host
The percentage of ethanol in his gasoline was approx. 40%....you did not read that wrong.
Turns out the customer filled his tank or added to his existing fuel in the tank with...... E85!
Running on a shop tank produced the normal good running characteristics the engine left with. Switching back to his tank again produced all of the symptoms outlined by the customer.
Customer claimed that we had told him this was the best gasoline to run. That did not fly well and he was charged for pumping close to 100 gallons of fuel and disposal plus troubleshooting time.
To give you an idea of what kind of energy Ethanol produces compared to gasoline there have been many studies done. In general 1 gallon of E85
has 73% to 83% of the energy of one gallon of gasoline. The variation is due to the amount of ethanol in E85. In essence the E85 leaned his engine to the point it would no longer run high speed nor did it have the proper mixture to accelerate.
pic host
