All turned out fine, I was careful when removing the foot so replaced the water pump kit and carefully put back together without the shifter moving.
One thing I did was to use a short ratchet strap to hold the foot in place while lining the waterline, driveshaft and gear shaft up.
Of course this is about the simplest of repairs for most of you guy.
I thank you for the input.
