same reasons motorcycles use one carb per cylinder (with a few exceptions).
air and fuel flow.
A 150hp V6 no matter if it's 2 or 4 stroke would require a huge carburetor, and a carb that big would need a whole lot of "work" to make it idle and/or start acceptably. So, it's cheaper to manufacture with 3 twin throat carbs. Fuel flow is important too, with a single large carb, the jet would need to be so large to pass enough fuel that it makes it much harder for atmospheric pressure to force fuel through it, resulting in POOR cold starting and low speed performance, plug fouling, etc.
On small 2 stroke stuff, the starting and idle quality is much better with one carb per cylinder. You will see that on higher end outboards, multiple carb 2 or 3 cylinder. On lower end motors, single carb feeding 2 or 3 cylinders is common (Mercury tower of power is a good example)<--and those things were notoriously hard to start back in the day (I remember them well). Nowadays they're mostly novelty. Inline 4/6 cylinder and Chrysler had some 5 cylinder inlines as I recall.
4 stroke stuff is designed for good idle and low speed running so they almost always have one carb per cylinder on 3,4,6 cylinder stuff. Twin cyl stuff can get away with single carb. On the twin cylinder stuff they are usually very small engines (25hp and under) which will run pretty good and smooth with a single carb.
if an engine has multiple carbs, they need to be synchronized if they're ever off/apart (and they probably will be at some point in their lives). Synchronizing makes a huge difference in all areas from starting to full throttle and everything in between.
