Didn't realize how many of my friends paid for lube changes. It's really simple if you have a motor like mine. Here's a video I made that might inspire someone to DIY. Now all I need to do is learn how to change the pump inside. That's expensive!
https://youtu.be/HHI_lUcpy-0
Changing Lower Unit Lube - DIY
- 8
Re: Changing Lower Unit Lube - DIY
There is videos on that too.. every brand of motor is slightly different in regards to the shift linkage, but the job is basically the same.
Sent from my SM-G960W using Tapatalk
- 3
Yep, chainring the pump on most motors is dead easy.
It’s all the bull you may run into doing the job that will get ya!
Sailbad the Sinner
- 4
Nice video. I wish my Honda's plugs used the hex wrench instead of a slotted screwdriver. I always fumble around getting the bottom plug aligned and back in. Don't know why. It is like my nemesis. Lol.
Have Rod - Will Fish
- Site Admin
- 14
Thanks for posting the video link! I will put it on the homepage!
- 8
If you put the top in first you can take your time with the bottom.. the drop or two you may lose is no big deal.LDUBS wrote:Nice video. I wish my Honda's plugs used the hex wrench instead of a slotted screwdriver. I always fumble around getting the bottom plug aligned and back in. Don't know why. It is like my nemesis. Lol.
- 2
good to know!RaisedByWolves wrote: ↑30 Jan 2021, 12:48 Yep, chainring the pump on most motors is dead easy.
