Adding grease to Bearing Buddy
Trailer related issues and discussion goes here.
Lowe14owner
5
Post by Lowe14owner »
HI! This is my first ever posting here. I've reading and learning a whole lot, and I love TinBoats!! Now, I have a question, and it's probably already been addressed, but I can't find it.
I packed my trailer wheel bearings over the weekend--the first time ever for me. When I went to get the seals, I also picked up a can of lithium wheel bearing grease along with a set of Bearing Buddys. Packing the wheel bearings went pretty well, I think. The problem is I didn't think about the grease for the Bearing Buddys. The grease I used was Champion Disc Wheel Bearing Grease. Unfortunately, I checked Champion's website and found that this grease does not come in tubes.
My question is this: can I use another lithium complex grease in the Bearing Buddy? Or, do I have to go back and repack with a wheel bearing grease that comes in a tube?
lckstckn2smknbrls
Post by lckstckn2smknbrls »
I've always heard not to mix greases. At this point I would leave the bearing buddies off and just use the dust caps.
bcbouy
Post by bcbouy »
grease is grease.it won't catch fire or something if you mix them.some have different applications viscosity/heat wise.as long as its axle/bearing its ok.
if all else fails....stop using all else
Loggerhead Mike
Post by Loggerhead Mike »
IMO-Buddy bearings are only good for falling off while you go down the road or allowing water intrusion at the ramp.
NautiBuoys
Post by NautiBuoys »
As lckstckn2smknbrls mentioned above, the best rule of thumb is don't mix the greases. Mixing different types of grease can cause the bearing to fail; in reality, its the grease that fails. Example-mixing a sodium based wheel bearing grease with a lithium based wheel bearing grease will cause the grease to liquefy and fail.
Since you know what type grease is in the bearing just match it-get or empty a tube cartridge and pack it with your WB grease.
BTW, never had a problem with Bearing Buddys, but I can say the same for the regular trailer dust caps too...
earl60446
Post by earl60446 »
I got Bearing Buddys on my boat trailer. Noticed that they have a small hole in the side of them, what is that? Kinda defeats the purpose of them doesn't it? Seems like regular dust caps would work just as well, maybe better.
Tim
16ft 1989 Fisher SV-2 w 1988 48hp SPL Johnson "CIGAR BARGE"
(engine looks like a wreck but runs great)
Used to have 1972 14ft Lund w 1977 15hp Mariner
(engine looked great but always ran marginal)
XLINE SPORTSMANS CLUB
ggoldy
6
Post by ggoldy »
earl60446 wrote:I got Bearing Buddys on my boat trailer. Noticed that they have a small hole in the side of them, what is that? Kinda defeats the purpose of them doesn't it? Seems like regular dust caps would work just as well, maybe better.
Tim
Is that hole not a sort of 'vent'? Or pressure release? To prevent over filling?
Gary
Mary Esther, Florida
1436 jon
1954 and 55 Corsair 10 horse
Clinton 5 horse(haven't determined age yet)
1952 Johnson 5 horse
1940 Evinrude Elto 1.8 horse
NautiBuoys
The hole is an overfill/pressure relief vent so you don't overfill and blow out the rear seal.
Lowe14owner
5
Thanks for the responses. I'm going to go back and repack the bearings with a wheel bearing grease that also comes in a 14 ounce tube for the bearing buddies. There's no need to be worrying about the grease matter on the road to and from my fishing. I only want to worry about the number of fish I'll be catching. :D
Boat2fast
6
Post by Boat2fast »
You could always fill the grease gun manually from a tub. (From the days before tubes)
Take the pump off, pull back the plunger till it detents into place, fill the gun with a spoon or something, screw on the pump end, release the the plunger and push the handle in. Your done, full gun. You will need to pump a few slow cycles to work out some air maybe...depends how well you packed it.
Bearing Buddys will let water in, IF you don't keep them greased(pressurized).
They will also fall off, IF you don't install them right, or IF the hub bores are damaged.
The directions included with BearingBuddys deal with these situations.
DaleH
5
Post by DaleH »
Boat2fast wrote:Bearing Buddys will let water in, IF you don't keep them greased(pressurized).
The directions included with Bearing Buddys deal with these situations.
So true ... most don't RTFM!
#1) 1st tin rebuild, 18' Lund https://forum.tinboats.net/viewtopic.php?f=21&t=36583
#2) 25' Parker refurb from EMPTY hull https://www.classicparker.com/phpBB3/vie ... p?f=15&t=6
#3) 16' V-tin rebuild https://forum.tinboats.net/viewtopic.php?f=21&t=36465
#4 Procraft SV14
#5) 16' Starcraft entirely NEW Transom Skins https://forum.tinboats.net/viewtopic.php?f=3&t=37548
JMichael
Post by JMichael »
Boat2fast wrote:You could always fill the grease gun manually from a tub. (From the days before tubes)
Ha that's one of the first things I thought of when I read the post but didn't figure there were many that would understand about manually filling one up. LoL I couldn't begin to count how many 5 gal buckets of grease I've emptied by filling grease guns, to do the daily maintenance on a lot of heavy equipment.
Boat2fast wrote: They will also fall off, IF you don't install them right, or IF the hub bores are damaged.
or if you buy the wrong size. I've noticed that on the less expensive brands, there is often a size mismatch or quality issue where they don't fit into the hub properly and they end up falling off.
New River Rat
Post by New River Rat »
Bearing Buddy (the brand) lists quite a few sizes. Be certyain you purchase the correct one for your application. The wrong one could come off or allow water to enter.
My Tinny is a tool, a means to an end, if you will.
New River Smallies
Case Plastics Pro Staff
bcbouy
Post by bcbouy »
i lost a bearing buddy 2 years ago.the tire guy says to junk them and not use them. last year a trailer mechanic says they work great. who to believe? i keep them on.last season i drove over 5 thousand miles towing my boat down forest service roads and highways.no bearing failure.the bearings are 5 years old and have over 20 thousand miles on them.i repack every spring.
jethro
6
Post by jethro »
I love bearing buddy hub caps. I have them on my snowmobile trailer that I pull over 5000 miles a season. They are on my boat trailer too that get's at least 5000 miles a year. Never had an issue and I am able to keep them packed. I grease my snowmobile trailer bearings once a month at least.
I fish, therefore, I am.
1993 Starcraft SF 14 DLX side console with 25 hp Mercury 2 stroke
2003 Sylvan 2100 Profish walkthrough with 150 Mercury Saltwater and 6hp Mecury 4 stroke kicker
