Lightweight battery for kayak
Trolling motors, Fish Finders, GPS, Batteries, anything Electrical, post it here.
Ernest T. Bass
Post by Ernest T. Bass »
What do you guys recommend to power a 40 lb. thrust motor on my kayak ? I currently use a group 24 battery, and I want something lighter weight.
Thanks.
You aint seen the last of Ernest T. Bass !!
CedarRiverScooter
6
Post by CedarRiverScooter »
I got a AGM wheelchair battery for this same purpose. It is sealed so you don't get acid burns if it tips over.
eeshaw
1
Post by eeshaw »
Is the wheel chair battery a deep cycle?
MrGiggles
3
Post by MrGiggles »
The only real lighter option with the same capacity is a lithium battery, but they aren't cheap.
You could go with a smaller battery, but you're going to lose a lot of capacity.
Ernest T. Bass
Thanks. So I should look for a lithium deep cycle battery ? Any recommendations ?
MrGiggles
3
Post by MrGiggles »
Yes, if you are trying to save weight and retain capacity, lithium is the way to go.
I don't have any specific recommendations. I think most are pretty good.
CedarRiverScooter
6
eeshaw wrote: 23 Aug 2020, 09:23 Is the wheel chair battery a deep cycle?
Yes
Scott F
3
Post by Scott F »
There is a Dakota 12 volt, 100 amp hour Lithium battery, weighs 32 pounds and costs $900. A 54 amp hour Lithium, battery weighs 17.6 pounds and sells for $500.
Ernest T. Bass
CedarRiverScooter wrote: 23 Aug 2020, 07:52 I got a AGM wheelchair battery for this same purpose. It is sealed so you don't get acid burns if it tips over.
Thanks. I sent you a PM.
CedarRiverScooter
6
Earnest T - Don't see PM from you.
I got the battery from Blaine's farm & fleet. It was about $90 but that was a few years ago. I used it in kayak with trolling motor. I just bungee corded it in the storage compartment & extended the wires for the TM. I used the foot pedal steering cables that are normally used for the rudder to steer it.
It would go faster than I could paddle.
Good luck on your project.
GTS225
Post by GTS225 »
This is the exact battery that's in my hot rod T-bucket. It has to turn over a straight six, but I'm very pleased with it. AGM's aren't what I would call low-cost, but it's quite a good balance between cost and power output, which I think is what you're looking for. You may be able to find it cheaper elsewhere.
https://www.speedwaymotors.com/XS-Power ... 69945.html
Roger
Ernest T. Bass
Thanks guys. I will probably get one of the AGM batteries when the time comes.
Action
Post by Action »
i run 2 30ah lithium.....and 1 12ah for fish finder
Ebass30920
3
Post by Ebass30920 »
What kind of run time are you getting with those 30amp? I'm thinking about two for my rear trolling motor on my electric only tracker. Only used to make long runs with 60AH up front when they get in stock.
