portable transducer mount
Trolling motors, Fish Finders, GPS, Batteries, anything Electrical, post it here.
senkosam
1
Post by senkosam »
Other than having to drill holes to mount a transducer bracket or mount it to the trolling motor, I came up with this idea a few years ago:
Get one of these dollar store door wreath hangers or some other thin flat metal:
Cut it and bolt it to a board:
At the bottom, mount a board that's wide enough for the transducer bracket:
(Note the wire straps that secure the wire to the board.)
Use an easy on/off clamp to secure to the transom:
No matter how weedy, the transducer won't clog with weeds like it would attached to the trolling motor plus I can use different trolling motors (45 or 55 #) depending on which boat I'm using (10'V or 12' jon) and not have to change transducer mount.
This topic has 6 replies
You must be a registered member and logged in to view the replies in this topic.
Register Logout
