Post a pic of your Boat!
I'll start things off. Here's my 2001 Lowe 1652 VT jet tunnel with a 1994 Mercury 60/45 jet 2 stroke short shaft motor. It had manual tilt when I got the motor last year but I found a new power trim setup on Ebay and it was worth it. It has the optional floor and sides and I moved the center console forward 2 feet this year and added the windshield and grab rail. It spends most of the year from April through October in the water docked on the Delaware River.
Edit: Haha, I just noticed in the 4th picture down you can see the cracked engine cover from where the tree from Sandy fell on the motor. It broke some linkage and ripped the motor right off the boat it was on. It sat on the ground for a year before they guys I bought it from got it and had just got it back up and running.
Here is my new boat. 1852 blazer ss. 60/40 mercury 4 stroke tiller. Extended front deck, two rear live wells under seats. Deck lids over starter battery and 9 gallon fuel tank. Run the current river in Missouri. By myself with just fishing gear, gps, 28.5 mph upstream and 32 downstream. ImageUploadedByTapatalk1442544352.999272.jpgImageUploadedByTapatalk1442544381.775497.jpgImageUploadedByTapatalk1442544423.134704.jpgImageUploadedByTapatalk1442544445.193748.jpg
02' Alweld 1860 commercial hull.
Here's a pic of my boat after polishing it when I had the 40/28 on it and there's a pic of my 60/40 I have on it now.
2015 1752 Blazer SS
1993 Yamaha 115 Pro-V with new pump
1993 Trailboss trailer modified to fit the Blazer
2008 Motorguide 82lb. digital trolling motor.
Seaark rxjt 170 with 75 etec
2014 blazer ss 16/48
yamaha 40/30
1984 Polar Kraft 1444
Suicide stick steer
1996 Evinrude 50/35 Jet
Nice boat pictures guys.I really like the one where the boat is going around the bend
2015 Legend SS 1960v
2015 Evinrude 225HO
Have a 08 20ft North River Mariner with Yamaha 150/105 OB Jet,,, boat has 3/16'' bottom that's 6ft wide with a 96'' beam,, has a 12 degree bottom with a 14'' wide planing pad and a jet tunnel,,,30'' sides .125 thick,,,, it will run 8'' ,,, has a 42 gal fuel tank in its belly and carry 2 9 gal plastic fuel tanks ,, get about 1.5 mpg max,,,, runs 30mph with me and gear 25mph 3 n gear,,
