1993 Sea Nymph 16 ft vee
Looks like I needed a little more ACM so I got a sheet of 3mm for $65. Also using it to box in deck storage. If all it needed was a live well I could have doubled it up to make 6mm.
Storage will probably get vinyl inside.
The rod storage used up a lot of brain cells and I was already low on em. Got the socks off amazon. Home Depot had a nice stainless latch.
https://www.amazon.com/gp/product/B07F37LJ5W/ref=ppx_od_dt_b_asin_title_s00?ie=UTF8&psc=1
Light socket, trolling motor outlet, cig outlet, charger outlet, sprayer.
Changing up the console a little. When everything is pretty much done I'll nail down all the panels.
This is the problem I'm having with the 16', I've been at it so long I'm starting to change little things and end up dragging the whole process out...
