Front Deck Build
pbw
Front Deck Build
Post by pbw »
Goal: Build front deck from front seat to middle seat. Storage for one battery and baits.
Boat: 1987 Grunman 14 x 38 inch bottom
Supplies:
2x2 wood boards
Simpson Strong tie # rtb22 (I could only find these at home depot)
8x3/4 Self Tapping metal screws
Wood Screws
*will add more later
I'm using the Strong ties to connect the wood to the boats ribs (I'm surprised how strong they are once connected I can stand on one). Once I have all of the stringers installed I'll connect them together.
Current waiting on my drill's battery pack to recharge!
PBW
Post by Waterwings »
Cool! I like these step-by-step projects, as someone can always garner some good tips/ideas from them :)
pbw
Post by pbw »
Okay I'm calling it a night ran out of brackets! Off to Home depot in the morning. Starting to link them all together!
If you look at the photo above, in the center of the stringers the previous person cut a tunnel under the middle seat! I'm thinking of boxing this in with some tin or wood/plastic and making a rod holder it could hold 7 ft 2inch of rods!
Below trying to see how much reinforcing to do for the seat mount.
PBW
Lookin' good! :)
Great idea for rod storage! With the additional room under the new deck you could possibly build-in one or two small storage boxes.
Looking good!
Thanks for doing the build in progress picture taking. =D> This will for sure help others out.
Please use our Amazon Affiliate link. It costs you nothing and sends a few cents to the site.
pbw
Post by pbw »
That is my internal goal! When I found tinboats.net I was looking for how-to and ways to do this. I just found a few photos of finished boats with maybe one in progress photo. So! I'm try to document this and then in the end video how stable the boat is after all this.
If I'm doing something wrong or you know a better way let me know. Or If you wonder how I'm doing something let me know I already have two questions I'm going to answer after lunch.
PBW
As an afterthought of my previous post, is there any flotation foam in the boat? If not, maybe you could section-off/use the port/stbd sides under the new deck to fill with foam. Probably wouldn't add any noticable weight all all.
pbw
Post by pbw »
Waterwings wrote:As an afterthought of my previous post, is there any flotation foam in the boat? If not, maybe you could section-off/use the port/stbd sides under the new deck to fill with foam. Probably wouldn't add any noticable weight all all.
Only a little under the seats! I'm thinking about doing that, there will be several good places for this when I get the decking structure finished.
PBW
Cool! I would think that the spray-in foam insulation made for sealing cracks at home would work well, as it's high-expansion and would fill-up a void pretty good.
bassboy1
Post by bassboy1 »
Waterwings wrote:Cool! I would think that the spray-in foam insulation made for sealing cracks at home would work well, as it's high-expansion and would fill-up a void pretty good.
Be cheaper to buy some of the 2 part marine foam, and mix and pour it. Priced it out before. Plus, some people say that insulation foam is an open cell, which would absorb water, but I haven't checked that.
bassboy1 wrote: Be cheaper to buy some of the 2 part marine foam, and mix and pour it. Priced it out before. Plus, some people say that insulation foam is an open cell, which would absorb water, but I haven't checked that.
Good point. Not sure if it's open or closed-cell foam either.
pbw
Post by pbw »
Update!
Got some more work done this morning, changed some of the braces around, getting ready to go pickup our new mattress :shock: be back later.
Its slow moving but progress is moving!
PBW
pbw wrote:Update!
Your're putting a mattress in the boat to!? Just kidding! :wink:
Progress is lookin' good! :)
mtnbasser
Post by mtnbasser »
i like what your doing there. you going to have 1 heck of a casting deck when your done...
mtnbasser
Post by mtnbasser »
you gonna use 3/4 in plywood for the deck? i ended up using 3/4" treated and man its heavy. if yo are garage keeping it, you may be able to get away with non-treated cut down on the weight alot
