Building a LiveWell - Completed
russ010
Roswell, GA
OK.. I know a few of you have been waiting for this.. and it actually works (tried it out today)
So first things first... I bought a 500 GPH bilge to serve as my aerator AND bilge for the livewell. So after I got this, I went to Home Depot to buy some plumbing supplies. I had an idea of what I wanted it to do, but I didn't know what all I would have to have because I forgot to look at the diameter sizes of the bilge, so I call bassboy1 from HD and he gives me all the details as I knew he would. I should mention, this is actually his design - I just kind of tweaked it a little bit.
I'm pretty sure the hose size that I bought is 3/4" OD (outside diameter) and the ID (inside diameter) is 5/8". Either way, the hose clamps snugs it up securely and it's in the livewell underwater so I'm not worried about leaking. That hose runs from the bilge pump to the first 45 pvc. I got 1/2" threaded elbows, and the gray pvc is actually a 12" riser which is used for sprinkler systems. I would have used regular pvc, but this was only .99 cents and I wouldn't have to buy a full stick of 10' since they won't sell in pieces.
On the top of the riser, I put a 1/2" - 3/4 Side Outlet 90. The side coming up from the riser is threaded 1/2" fips (female threaded) and the 90 is 3/4". The pump is not fastened to the bottom of the livewell. There are 2 pvc clamps that are attached to the aerator pipe - this keeps the whole thing in the same position.
One side at a time...... The aerator side first.
Coming out the right side is 3/4" pvc into a 3/4" PVC Ball check valve. The next piece is about 18" of 3/4" pvc which has holes drilled in various places. I didn't care if I had a straight line of holes, I actually offset them one after the other so water would hit all over the livewell. In the very end is a 3/4" cap.
Bilge Side....
This side has a bout an 1.5" of 3/4" pvc that goes into a reducer. I took this from 3/4" down to 1/2" because I didn't want to buy more hose. I bought a 10' section and it was expensive because I got all they had in that one spot. They do have cheaper and I would suggest getting that. This 10' roll was about $18, ridiculous...
Anyways, the reducer is male threaded on the 1/2" side, and it screws directly into the 1/2" ball check valve. The fitting coming out of the check valve is a slip barbed adapter, which will let the hose slide right up on and then a hose clamp to hold it in in place. The hose is about 40" long and I drilled a hole dead even on the tub so that it can run straight out the front of the livewell and can be hung over the side when I'm ready to empty the livewell. When it's not hanging over the side, I can fold it up out of the way to the side.
Wiring...
Wiring is a little tricky. I wanted this to serve multiple purposes, so I installed a 12v power source for the livewell to plug in to. I wired the cigarette lighter first so I would know how much wire I needed to add to my livewell pump depending on its' location.
I started at 12v power source. I plugged a few different adpaters into it so that I could make sure that no matter where I installed it, everything with a 12v power adapter could plug into it. So, right in front of the rear bench, next to the side wall is where it was placed. It also made running wires to the battery easy because I could just run them down the side wall channel.
With that in, I need to get power from the battery. I found an old Minn Kota battery connector and fabricated it to work for me. This allows me to simply unplug the power source to the connector. Now this connector has 10ga wire, and I'm running 14ga. To make 14ga fit in a 10ga connector, strip off a little more line and bend it back over itself... then you can just crimp it down.
Here's what I have at the battery. This is one battery that is ran in parallel to another battery on the other side of the bench. The main terminals with the large connectors is my front trolling motor. On the studs, there is the trolling motor connector which powers the 12v power source, and the other is the 4ga cable ends running to the other battery.
The livewell is next to wire. First, I ran the bilge pump positive wire (brown) up the riser and down the bilge side of the livewell.. this is how I determined where to place my toggle switch. I placed waterproof connectors on this, and ran an additional power line (red) back to the 12v adapter (plug-in).
If you follow the wires to the corner, you'll see where I drilled a 3/16" hole to run out. I have about 36" of positive and negative wire so that I can move the livewell around a little bit if needed.
Filling up the Livewell...
I didn't want to carry extra stuff with me to fill the livewell with, so I got this 800GPH aerator pump from walmart on clearance for $10.. but I think it was mismarked. They didn't look, and I didn't tell at the register. Gotta love self check out!
Anyways, I had longer hose to draw water up with, but that didn't work. While out on the water today I took my knife and cut the hose to about 3". I don't know if it's even needed.. I ended up dumping the hole thing in the water and water started pouring in! I did attach alligator clips to power this - so no switch. I only wanted this to be temporary since I won't be using it but a few times throughout the day.
Pricelist...
Keep in mind a few things.. the braided hose I used is expensive stuff, and you don't need to use this kind. This was all I could find on the aisle I was on (I built this thing in my head while in the store).
Rubbermaid Tub, 22gal - $5 @ Wal-Mart
500 GPH Bilge Pump - $20 approx
PVC Fittings - $15 (the check valves are like $4-5 each)
10' 3/4" pvc pipe - $2
3/4" OD braided hose - $18 (get the cheaper stuff, but this stuff will last forever - atleast it better for that price)
Toggle Switch - $10
2 - 25' power wire rolls - $5
12v power source/plug-in - $6
Total Price - $85 roughly... You might have this stuff laying around like I did. I just priced it to help out with this post.
You don't have to put the bilge side in the livewell, but it sure does make it easy to drain. I put about 18 gallons of water in there today, and when I tried to pick it up... well, lets just say that water wasn't going to be poured out by me that easily.
i like it i made 1 the same way but you have a hose so that you can empty it but mine just has a cap at the end im gonna make another so that i can empty it easier :D
Not really. I stole it from the internet, so I can't take credit for it. He did modify it a bit more extensively than many I have seen on the 'net.
I amaze myself sometimes with what I can jerry rig while standing in 1 aisle at home depot for more than an hour.
you can see the toggle switch picture?? I only see half of my post. I don't even see the main stuff... I hit submit earlier while posting this and hit stop on the browser, then kept writing and hit submit when I was completely finished... please tell me the pricing is the last thing on that post - otherwise there is a ton of stuff left out!
i dont see it
I'm going to rewrite/edit this post.. .there is a lot of stuff missing... wiring, and all that jazz... check back in a little while, I'll have more added to it.
I have another pump to fill it with.. you checked it right before I updated it, so check it again...
As far as cooling it.. I'll freeze a few 1L bottles of water if I have to to keep the water cool.. I can keep those in my cooler with drinks. One thing I'll do though is fill the water in the morning when I get to the lake... Shouldn't be too big of a problem though, I can fill and refill/drain throughout the day if it gets bad.
Sorry Russ that's not gonna work, it will be a failure, so I must do my duty and help my brother fisherman from this soon to be disaster of a live well, let me PM you my address so you can send it to me and I will put it in my, I mean throw away this live well for you :---)
scouts honor :mrgreen: :lol:
crap - now that you mention the top, I'm not finished....
I plan on cutting out a rectangle (not sure of size yet), and using a piece of the aluminum bench top that I cut out of my boat. I'll attach it to the top of the tub with a stainless steel piano hinge fastened with rivets.
I forgot how high exactly it sits above the rear bench, but I think I could deck around it. Then I could put insulation around the bottom side of it to keep it at desired temps.... (this edit comes in after HiH (hoist-n-hawgs) gives me the idea for insulation.)
Outstanding instructional post Russ! =D> I have a draw full of inventions 80% complete. Now if I could I borrow your brain for a day or two for the final 20%, they may actually work!
On the "keeping it cool" subject, you may want to consider some sort of insulation. I've tried something simuliar in the past(didn't look anywhere near as good as your's) using ice to cool them off during the warmer months. Can yu say FISH BOIL? #-o I also had a Taho livewell and delt with the same problem. I wrapped it w/insulation(cover and sides), then duct tape. It worked, but esthetics were an issue.
Great work and it looks good too! :beer:
I'm going to wait and see what happens when the water's get warmer.. Here in the south the surface temp of the water can get up to about 95* or higher... most places I fish average about 89-93*.
The plan I have so far is filling the water when I get to the lake, and insert a liter bottle of frozen water. Actually, what I plan on doing is filling up a 2L bottle first, cut the top off and put that block of ice in, then direct water coming in from the lake to run over it... that's how you get cold water. Then put 1L frozen bottles in to keep it at the desired temp. As water changes are necessary, I think I'll cut the top off of 1L bottles and do the same thing. I can fill/refill at the same time, so shouldn't be too much of a problem. But we'll have to wait a few more months before we get that kind of temp. I plan on putting some kind of aquarium thermometer in to keep an eye on the temperature. When the water gets around 70*, water should be changed out every 3 hours. This is what I'm shooting for to start with.
I've been thinking about this livewell now for the last few hours and decking... I think I can make it happen, but this thing sits higher than my bench seat. I could cut out the floor the dimension of the bottom of the tub, then build up around it to match the rear bench so that I have more platform... but I think what I am going to do (don't know why I didn't think of this in the first place) is go to my brother-in-laws HVAC shop and make me one out of sheet metal. Then I can insulate the outside of it with HVAC insulation, and make it the dimensions that will allow it to sit even with the rear bench. He has all the machines to make it happen, I just have to get back to SC in my free time to build it.
