My First Build - 12' 40" Meyers Jon Boat (updated 5/24/2010)
Troutman3000
My First Build - 1240 Jon Boat
Post by Troutman3000 »
Going to add these bad boys now insteasd of the other seats. These will look cool and should last a lot longer....
Troutman3000
Made some progress this weekend.
Carpeted my decks.
Installed 2 inch foam under the floors.
Got my seats and seat base.
I sould have more detailed pics this week. I designed my front deck to be removable.
However I still need to paint and steelflex.
Bolt and seal the transom and bolt down the decks.
Ran out of carpet right before my last piece.(hatch lid)
Troutman3000
More pics....
Looks good man! =D>
Troutman3000
Thanks Brine....
dyeguy1212
Post by dyeguy1212 »
Really coming together nicely =D>
Troutman3000
I did have one goof up that I had to improvise on. I bought a small can of sealer stain from home depot to do the transom with, little did I know I bought the dark "base" without any color. I didnt want the transom to be natural wood color so I mixed a dab of my olive pigment from my steel flex. I was unsure how it would turn out but it ended up working very well. I put about 5 coats on the transom and its water tight now.
raven174us
Post by raven174us »
That's some great work. I'm looking for my first project and its great to see all these great mods.
Troutman3000
Made some progress today.
Got the steel flex done. Had a couple spots were it sagged a little but i had to gob it on the seams real good. You cant even see it, but i know its there.
I rolled it like paint and put it in a tray. I thought it was easier that way.
Picked up a trailer for $175. Fully adjustable and ready to go.
WHAT COLOR SHOULD I PAINT THE TOP?
perchin
Post by perchin »
Looking good man. I just wish it would stop raining here so that the temp would come up a little. What kind of roller did you use?
Troutman3000
High density 4" foam rollers from Home Depot. The temperature is very important, I tried using the stuff this morning before it warmed up and it was a nightmare..
Troutman3000
Finsihed steel flexing.
Now to primer and paint inside and add "racing stripe".
perchin
Post by perchin »
:shock: Wow, the finish you got rolling it on is most impressive. I can only hope mine goes on half this good. =D>
Troutman3000
Its on there good and it has some texture in there as well, which was good because it breaks up the imperfections of the hull....
Troutman3000
Got the outside done but took it to tribble mill and didnt seal the transom area....ooopppssss.....had to come home and patch it up...........
