Want to start modifying my 15' V-Hull that i just got
alanbird_87
Post by alanbird_87 »
I finally got my boat sea worthy!! It is a 15' V hull 1972 Monark with a 79 25hp Johnson on it and an old motorguide trolling motor. I had to do a few things to the trailer its on such as new rims and tires and leaf springs and to the boat i repositioned the trolling motor to make it more secure and gave the gas motor new spark plugs, new wires, new water pump and and two transom mount bolts instead of big wood screws. There are also a few other modifications i want to do to the boat. I want to add a deck to it (not a real high one) with some storage space such as a rod locker, a live well, and a place to keep battery out of my way. The boat has three bench seats in it that if i could take the middle one out to provide more space. But the middle seat is riveted in. How could i remove it, and if so will i lose hull support and could this support be replaced or would it affect the boats performance drastically? If anyone has any suggestions please reply. I plan to get pics up soon so bare with me.
lcdr frank
Post by lcdr frank »
One word...DON'T. You will loss the support the seat provides which results in flex in the hull. With alum you will shorten its life and are asking for failure of the hull structure.
Frank
Troutman3000
Post by Troutman3000 »
lcdr frank wrote:One word...DON'T. You will loss the support the seat provides which results in flex in the hull. With alum you will shorten its life and are asking for failure of the hull structure.
Frank
If you can supply some other kind of support in the seats place it is ok to remove the seat imo. Many have done it on this board, but it really depends on what kind of water you plan on getting into.
alanbird_87
O ok thanks for the advice, but could you look at buffords mod to see if you think this will work on my boat?
Troutman3000
alanbird_87 wrote:O ok thanks for the advice, but could you look at buffords mod to see if you think this will work on my boat?
I cant make that call for you.
SVOMike86
Post by SVOMike86 »
Pretty sure CrappieSlayer did a mod to support his sides that would work for you.
alanbird_87
Got some pictures today and also started working on front deck let me know what yall think.
sturdi87
Post by sturdi87 »
I would say it has potential! The front support for the front deck, how is that supported, looks like it is screwed to a factory bench correct?
Also, yes you could take your middle seat out, I sure know I would want to, but yes you would be losing some support/structural integrity, so yes you would want/need to do some redneck engineering to make up for this, but it certainly can be done. I haven't done it personally, but there are so many examples on this site of people doing it, seemingly successfully. As well as different schemes for bracing it up etc., that I conclude yes you can! So do some lurking, get some ideas, and I'm sure you'll figure out a way to do it! I think it will be a lot of work though...
Hows that motor run? If I were you if the rig is in usable condition then I would be using it right now! I got my rig over a month and a half ago and thought I could be on the water in a week, well a month and a half later and it hasn't been wet. And the bass are biting. I'm just missing some linkage for my steering, as soon as I get that then all mods stop for now!
My 14' V project with 40hp Mariner and 7.5 Johnson: http://www.tinboats.net/forum/viewtopic ... 21&t=12448
alanbird_87
The front support for the deck is screwed into the front seat and it supports the front deck nicely. I have a few more pics of the front deck carpeted and with a seat on it so as soon as i get the time i will post it. Also, the motor runs great! only porblem is that it sometimes wants to jump out of gear, maybe the clutch dog. I need a new prop for it cause its all dinged up and scratched. I have had it on the water fishing about four times since I've had it. Only thing is I took it off the trailer to start paint about a week ago and have not even touched it yet because of school. But school is almost out and i should resume progress soon, hopefully tomorrow. Thanks for the pointers, though.
Troutman3000
Looking good so far man.
alanbird_87
Finally got some pics of the painting process! 4-27-10 I used paint stripper to remove the paint from the boat. Worked very well but messy. Also got the tongue of the trailer painted black instead of it looking rusty. Hopefully, I will apply paint to it Thursday afternoon!! Let me know what u think.
dyeguy1212
Post by dyeguy1212 »
Looking good... removing paint is always the fun part...
alanbird_87
Some more updated pics 4-29-10. These are some pics of the primer application. Hopefully i can put some paint on later this afternoon!!!
Boater
Post by Boater »
I have a 14' and removed the center bench seat in mine, I have photos of the mods done to strengthen the hull here is the link to my posts on this site. https://www.tinboats.net/forum/viewtopic.php?f=3&t=10823 If you have any questions hit me up.
BottomDweller
Post by BottomDweller »
Just looiking at your trailer and trying to see what was done with the tongue. Was it cut and then an extension bolted on underneath?
