TruckMechanic 1436 ReBuild Updated 4/21 - Almost Finished..
Truckmechanic
Post by Truckmechanic »
Well, I finally started on my ReBuild. Here is the pics of what I am starting with.
OverView of Boat
OverView of Boat
View of Front Fishing Area
Battery Area
Truckmechanic
TruckMechanics 1436 ReBuild
Here is my plans, I am not going to far with it :D ..as I don't want to buy new carpet.
The front area at trolling motor mount is weak - Needs new wood and possible lighter, It is way to heavy in the front. - DONE
Floor in second section is broken and rotted. - DONE
Rear hatch to cover gas tank, Although I am not sure about it yet. - NOT DOING
Clean up wiring and try to hide and make neat and clean.
Seats need permanet mounts with new seats and pedestals. - DONE, Just WAINTING ON PAINT TO DRY
New Electronics added.
BlueWater LED's installed.
Bow light socket
Have a new fuse/switch panel for lights
New tires on trailer
New safety chains on trailer - DONE
Truckmechanic
I also starting taking it apart yesterday. I had 3/4" OSB for my trolling motor mount. When I removed the carpet and motor the board broke in half. I Took a picture of the wiring down there also that I am going to redo.
I also started on the flooring, I wasn't sure how well my carpet was going to come up but it came right off, which I was happy about because I shouldn'thave to buy any now. The rot was worse that I thought.
Picture of Floor Rot
Picture of the wet rotten wood for the trolling motor/switch area.
WhiteMoose
Post by WhiteMoose »
I was going to comment that it looked pretty good as-is in your first picture.... then I saw your 2nd set of pictures. :) Actually your boats set-up is almost exactly what mine will be when all is said and done. Have fun!
Truckmechanic
Well I made some more progress although not as much as I would have liked. I have the rest of the rotten wood removed and started making the templates for the trolling motor mount.
I still have to figure out what I am going to do with my wiring.
I also have to get foam board and put under the new floor or could I do without. I was thinking it couldn't hurt.
Truckmechanic
TruckMechanics 1436 ReBuild Updated 4/1
Well I got my flooring cut out today but I picked up the wood last night before work. After seetting in the truck all night it got a bow in it. I cut it out and left two blocks laying on it for the night. I hope it relax's and lays down flat.
I also started on my seat mounts. I have these aluminum plates, They are 12" x 12" x 1/4". I decided to use it for at least the front mount. I am going to use 6 toggle bolts to mount to the bench and then I have 4 elavator bolts that will hold the pedestal down. I have drilled all the holes and polished, Now only thing to do to it tommorow is paint. I ran out of time today or I would have painted before work. Do you think these will hold 250lb me down?
Planning and Layout
Finished before Paint
Truckmechanic
TruckMechanics 1436 ReBuild Updated 4/4
Well I made some more progress. I now have the floor and sides down and the carpet glue is drying. I am starting to feel like I am getting somewhere now.
Truckmechanic
TruckMechanics 1436 ReBuild Updated 4/8
Well I made some progress over the last few days. I now have my seat bases all grinded down and painted..I am letting them dry currently. I have installed my new safety chains on my trailer also. Once I get the seats on pics will come.
Truckmechanic
Well. I have the trolling motor mount all done, All the wiring has a wiring harness now. New safety chains installed. Working on the conduit and the finishing touches...Also got some of the BlueWater LED's installed. WOW...I think I over done it on the front. I can't wait to get the rest of them installed. Sorry for no pics of them at night. Tommorow morning after work.
Truckmechanic
Forgot the pic of the Conduit I am using. Paint matches perfect to the boat so I think it will blend okay. I am not completly satified but it will have to work for now.
Troutman3000
Post by Troutman3000 »
Looking good man.
Where could I get a trolling motor hook up (the part that connects to the batttery) ? I need one for my 24volt motorguide.
Truckmechanic
I bought my plugs at Gander Mountain.
Truckmechanic
Got my BlueWater's installed...The pics doesn't do them justice. I don't know how anyone could ever live without them...
TruckMechanic 1436 ReBuild Updated 4/18 - BLUEWATER INSTALL
Post by Waterwings »
Nice progress pics, and liking the Bluewater LED's !
fishfast41
Post by fishfast41 »
Well, I'd have to say you definitely got the answer for night lighting there. As I fish at night often,I will for sure be putting those on my boat.
Our Lord Jesus saved me and changed my life. He will for you also, just ask Him to.
