pbw
Do you just let the new line's "spool" go rolling around the floor or do you mount it to something?
BassAddict said:what kind of reel ya spooling?
be careful... you would be surprised how much damage you do to your line that way. now if you took a wet/damp cloth inside the book that would work just wet your some kind of lubrication..Fishin NJ said:I put the spool on my floor then run the line through the center of our phone book a place a light book on top of that.
I then go through my eyes to the rod and connect to the reel. I sit about 10 feet away and start reeling, i keep my rod tip high with just a slight curve to the rod tip as well as keep the line going through my fingers by the reel, reel in to the spool is 3/4 full cut and done. adding to taking away weight on top of the phone book sets your tension.
This is for a baitcaster for spinning you need to be sure the line comes off the spool in the right direction or you will get birds nest like crazy!!!!!!!
my father in law would switch his braid this way . after half the season he would hook it to the fence walk it off tie the end to the fence and reel the old stuff on the bottom..kentuckybassman said:I found the best way to do it is just reel it on anyway you can (I usually just leave it in the box and try to keep it on it side) and when it gets full,tie it off to a fence post or the corner of the house or whatever you can walk off all your line and then reel it in while keeping the line pretty tight as you reel it in.Works great and it doesn't get all the loops in it (especially on spinning reels) and your line is stretched just enough to be spooled good and you'll even cast it better!
pbw said:BassAddict said:what kind of reel ya spooling?
My new bait caster I got for Christmas. Bass Pro Shops® ProLite Finesse Baitcast Reel and Rod Combo
pbw said:pbw said:BassAddict said:what kind of reel ya spooling?
Let me say again I've been doing some practice with this combo and I love it. You really have to try to bird nest it! It doesn't need much weight at all to cast. I'm going to buy another with a stiffer rod...
It is sweet I can change line on 10 reels in under an hour that includes stripping the line. you will be very happyJim said:I just lay the spool on the ground and then hold the line with my fingers one foot in front of the reel. I then let all my line out behind the boat and then reel it it and then I tie on a lure.
Im thinking of picking up the machine Redbug has....The Berkly spooling station.
