slim357 said:
SMDave said:
I like Berkley Trilene Fluorocarbon; just don't get Berkley Vanish. That stuff is garbage. I also know some people swear by Berkley FireLine, a superline like Power Pro, it is considered "fused line," not braided, and has a little thicker diameter than power pro and other braided lines.
Dave Ive used both Vanish and FireLine, and i think the vanish is 10times better, i think fireline is the garbage, but thats just my opinion, to each his own.
Hey man... I didn't say I use fireline 8) . And I hope you aren't saying Vanish is good :evil: .
Anyway, finesse; it's basically doing a presentation that will get inactive or finicky bass to strike. This usually means smaller lines to decrease the visibility when fish are more finicky and lineshy. This also means downsizing baits usually, because when bass are in "finesse" or "lockjaw" mode, that means their metabolism slows down, so they aren't looking for big meals because they take way too long to digest, and they need energy from the food quick. Finesse bass can be suspended, in cold or hot water (not in between). So finesse is usually associated with small lures, and light lines, and that is usually the case. However, you can "finesse" a jerkbait or crankbait by simply fishing it slowly, or doing a "jerk jerk jerk long pause" retrieve, which is usually thought of as a finesse technique. However, it can be done with 20lb line and a 7" jerkbait! Crankbaiting is similar. It also depends on wobble and such.
However, "finesse techniques" as most anglers know it is small lures and light lines, like a dropshot or shakey head rig. They are, however, ALWAYS fished slowly, coaxing the sluggish bass to get off their lazy tail fins and bite that lure. Often times, "lockjaw" bass will easily pass up on a fast moving meal.
By the way, finesse is also for pressured bass (bass that have seen a lot of anglers on the lake!).
For all that brush, I recommend using Power Pro. There is no better line for fishing in the weeds and brush! I have ripped limbs straight off of trees with Power Pro (30lb. test). It has saved me a lot of embarassing moments from fellow fishermen and watching bystanders, and can mean the difference between a day of fishing, and a day of squirrel fishing!
Good luck!
