wiring tip
fowlmood77
Williamston, SC
Here is a tip for all those wanting to run a trolling motor up front with a battery in the back. To get large gauge wire to supply the power, you might be able to find two set of jumper cables cheaper than you can buy the wire alone. Cut off the clamps on the cables and splice them in to supply your TM.
Thanks for the tip. I am waiting for my TM, and charger and to arrive via ups. I have 4 batteries to hook up/2 at the bow to at the stern. I want to run the elctric wires with the exhisting wiring in the boat, which are located in the rod holder storage area. Any recommendations on feeding these wires with the exhisting wires. The openings are small and unreachable by hand.
You got two options
1- get an electricians fish tape - run it from one end - tie on the wire and pull it back through
if you dont have a tape and the existing wires are not tied together in the run
2- you can cut one wire on both ends (make sure it is the same wire) - tie on some mason's string - pull the string through with the wire - then tie on the new wire with the old that you just cut - pull through and resplice the wire you cut
In either case you will want (if possible) to run an extra line of string along with the new wires in case you ever need to run more wire in the future
Hope this helps
Sammy
