Did a shakedown run today to check for any bugs before I add all the finishing touches. Everything went awesome, except for my rear hatch caving in. I thought the 10 screws holding the hinge in would be enough, but I used short ones so they wouldn't poke through the underside of the wood...well they weren't strong enough and while I was kneeling on it to adjust the trim it collapsed! It's an easy fix, I will add some of the 3/4" square tube and bolt through wood and metal instead of screwing into just wood
I had some insanely beefy gunwale braces made up that attach to the middle seats, but the boat is so solid I will probably go with something a lot smaller and less in the way.
Everything is really solid
I tried to "jump" my wake and see if the boat had any flex or weirdness going on, but nothing budged. The 2 hp motor putts along at great speed for trolling, the 35 'rude ran awesome, and the seating position was perfect! I was worried that it might be a bit uncomfortable reaching back for the tiller, as some of the tiller boats I have run in the past have been a real chore to handle, but it felt great and I never felt like I was fighting it. I'll probably add a tiller extension for when I am running the river since there is no shortage of debris floating down, and standing up is the only way you can really see what's in front of you when visibility is at 4" (It's like chocolate milk early in the season, and full of little landmines.)
[youtube]K198Pj9PL6A[/youtube]
