Battery Vibration Reduction
Northwest KY. Fairweather angler
I got tired of my batteries shifting, although it was slight, when in-tow and I'd hit a rough patch of road or a bump, so I figured I'd try to eliminate/reduce the shock to the batts. I used a piece of an old camp sleeping pad for the task. I cut the pad into 1" wide strips and placed them flat around the inside perimeter of the battery trays then set the batteries in place, then attached the standard battery straps over them. Seemed to stop quite a bit of movement when I tried to shift them by hand. Hopefully this will dampen the shock/vibration to the batteries.
