switch panel and fuse box ideas
BBQ197
I need a place to mount a switch panel and fuse box. I want it to be close to me when I'm running the boat (tiller). My boat is a 14' flat bottom. What ideas do you all have on how to mount these things so that they're relatively waterproof and within easy reach?? Bring on the pics!
Here's how I mounted mine.
I made a bracket that goes inside the hole for the buss bars to mount to.
Used a PVC electrical box and mounted to the transom. Simple and within easy reaching distance.
The switch panel has built in breakers, so no separate fuse panel was necessary.
i'd love to see more pictures, trying to make my own switch panel as well. i only need 2 systems, nav/anchor lights and bilge. i cheaped out & bought 3 switches rather than a fancy 3 way for the nav/anchor. rather than cut into the benches, i'm thinking of putting my panel in a box on top of the rear bench. making it strong enough to step on & protecting the switches from being hit by having them shrouded top & sides. it will also need to house the key switch & emergency stop lanyard switch for my motor. i'll probably build something like this out of diamond plate & aluminum angle assembled with pop rivets:
images
everything on mine will be straight-wired to battery no fuses, i like to live dangerously lol
I got it at my local hardware store that has a good selection of electrical supplies. It's hard to tell in the pictures but I ran some of the wires in from the right side and some from under the bench, you can just barely see the down turn on the left side. When I get a chance, I go take some more pictures.
Here is a similar one,
https://www.homedepot.com/Electrical-Electrical-Boxes-Conduit-Fittings-Boxes-Brackets/h_d1/N-5yc1vZbohn/R-100404096/h_d2/ProductDisplay?catalogId=10053&langId=-1&storeId=10051#.UTkcH9b1TPY
